speedo swap? HELP!
Old Nov 16, 2007 | 02:25 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
speedo swap? HELP!
getting ready to take on the project...going from a 85mph to a 145 unit in my 85 iroc.do i need to change the speedo gear in the tranny.if so where would i find one??305 tpi 700ra 3.23 rear?thanks
Old Nov 16, 2007 | 02:30 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo swap? HELP!
Straight swap. Instead of swapping entire clusters, however, I'd recommend swapping only the speedo heads (providing your original cluster works as designed). No need to change the drive or driven gears in the trans unless you've traded rear ends. Check the following link for more info:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Nov 16, 2007 | 03:25 PM
iv recently swaped a 3.23 posi for my old one tire fire(ratio unknown?)where could i get a different gear?thanks
Old Nov 16, 2007 | 03:38 PM
JamesC's Avatar
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Jorlain
Aug 24, 2022 05:11 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
