Cupholder Help!
Old Nov 17, 2007 | 11:38 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Cupholder Help!
I got a set of cup holders for my '88 Firebird, and after the power window conversion i'm stuck staring at my doors trying to figure out what hole pattern these cup holders use. I've sat for about an hour or so reading past threads and i've read that they fit in the older birds too, yet i can't find anything, and the only spot that resembles good positioning needs 2 holes to be drilled for the bottom two and the 3rd upper hole is blocked by the regulator. I guess what i'm asking if someone could possibly take a picture from underneath the door panels for me and arrow out the holes that are needed. And if i need to figure out a custom set-up (if the doors had special provisions for them in '90-'92) then anyone figure anything out??? Thanks for any help!
Old Nov 18, 2007 | 01:54 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Cupholder Help!
Yes the newer doors have 3 square holes that a plastic plug (similar to those used to install license plates) goes into. Your doors won't have the holes, so you'll need to hold them in place and punch a hole with an awl all the way through your interior panel, then drill holes and screw them in place.
Lon
Old Nov 18, 2007 | 01:25 PM
84redta's Avatar
Re: Cupholder Help!
Any chance anyone has thier door panels off or work for a junkyard and have a car that has the door panel off, i'm just trying to stage where the holes are in the newer doors so i can get a feel for the places i need to drill the holes. Thanks for any help!
Old Nov 19, 2007 | 10:14 AM
84redta's Avatar
Re: Cupholder Help!
bump
Old Nov 20, 2007 | 04:40 PM
84redta's Avatar
Re: Cupholder Help!
bump
Old Nov 21, 2007 | 11:40 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: Cupholder Help!
I have mine off but I just sent my door panel with the cup holder (I only have drivers side but it's the same) out to be recovered to math my new recovered seats so I can't help you with pics. To be honest I just set the holder low enough for those litre' cups and I drilled three holes and mounted it to my door panel. This is the first i heard there may be door hole but I have a camaro so who knows. Any way just putting holes in the door panel was strong enough.
Old Nov 22, 2007 | 12:06 AM
84redta's Avatar
Re: Cupholder Help!
Yea naw i'm cofortable just putting in holes, as far as i know only firebirds got these (assuming since 90-92 has special square holes i'm guessing the firebird doors are diff from same year maro's) but i was just hoping someone can take a shot of thier door, not the door panel, so that i can see in relation to the power window motors their square holes were so that i can get a feel for where i need to look. Thanks though!
91TealRS
May 12, 2002 11:01 PM
IROC-ZWV
Apr 1, 2002 04:02 PM
rjmcgee
Dec 13, 2001 10:27 AM
25th anniversarry RS
Feb 25, 2001 09:38 PM
