Passenger side sunvisor hits rear view mirror?
Old Dec 4, 2007 | 11:06 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Whats going on here? Every time my passenger uses the sunvisor it smacks into my rear view mirror throwing it off. Do I have some mismatched parts or something? I have a hard time thinking these cars made it though production with an issue like that.
Old Dec 4, 2007 | 12:24 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Passenger side sunvisor hits rear view mirror?
sounds like the mirror is sliding off the post??? Unscrew the screw in the headrest, slide it towards the door, and try re-screwing it in. You may need a new bushing kit or whatever they are called for it replacing the plastic insides of the sunvisor.
Old Dec 6, 2007 | 02:02 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
If you have the really awesome mirror like i do with the lights on it, its has two swivels, one lets you ajust it while the other usually never moves, i had the same problem, also realized i could put my mirror up really high, becsuse it was sitting very low and too the side.
pfsteichen
Feb 9, 2016 06:59 PM
Street Lethal
Aug 14, 2015 08:25 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
