Upper door panel trim seal zip-tied
Old Dec 30, 2007 | 11:09 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Suggestion for reattaching inner sweep seal: I was mixing and matching door trim pieces and found most had at least a couple broken heat stakes retaining the seal. I didn't want to use screws for clearance and rattle issues. Small zip-ties worked really well.
JB Weld worked well for bonding the lower panel to the upper. Cure for broken pal-nut post and correcting some warpage of the upper.
Old Dec 30, 2007 | 02:44 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Upper door panel trim seal zip-tied
Here is what I did, it worked really well.
https://www.thirdgen.org/forums/body...ls#post2781881
Old Dec 30, 2007 | 05:16 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Was that method visible from the outside with the window down? You did a good job talking to yourself, BTW
Old Dec 30, 2007 | 05:27 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
LMAO,
The window never went all the way down so I never saw the heads, one could always attach a self adhesive round piece of velcro, paint them, or something but I didn't have a problem at all.
Old Jan 1, 2008 | 01:22 PM
ACCLR8N's Avatar
Have you driven the car since you did this? I don't see how the nuts can't be touching the sheet metal.
Old Jan 1, 2008 | 03:52 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
They never rubbed on anything, thats why I used panhead bolts and they were barely long enough to get a nut on the back. It worked perfect for me and I never had any problems.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
Out-Cast
Aug 23, 2015 06:33 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
