Converting a 110mph to 140???
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
I am thinking of putting white overlays on my 91 110mph cluster.
What makes the needle sweep at the 110 or 140 rate? Is it a difference in the vss or in the cluster? I would assume it is in the cluster. If so, can it be modded to sweep at the 140 rate? Possibly a different resistor or such?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Converting a 110mph to 140???
what car? bird or maro'? The birds are electric, and you can just swap out the speedo for the 140 unit. I think the camaros were all electric by 91 you you can probably do the same
Engine: several
Axle/Gears: lots
Car is a 91 camaro.It is electronic. I have already swapped the cluster once due to the speedo being glitchy. I was just thinking if I was going to add the whiteface overlays, I could go with the 140 overlay set over a 110 speedo and have the 140 speedo without having to buy a 140 cluster.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, you must replace the speedo in the dash with a 140 MPH one.
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Engine: several
Axle/Gears: lots
Yes, and I still think it is possible.
All you are doing is changing the rate that the needle sweeps. It is an electronic drive, so a different resistor rate or such should do it.
Only problem, I do not have a full function breakdown of the circuit or enough electronics knowledge to correctly modify it.
It was just an idea that I was wondering if anyone else had tried.
I actually think it could be accomplished other ways. If you change rear gears, your speedo will not read correctly. To correct it, you modify the signal, which really only modifies the speedo sweep rate. Basically the same thing, just a different reason.
Read the tach fix thread, there are people that could do this, I just am not 1 of them.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
it is possible check out http://www.transmissioncenter.net/sp...0gear%20driven
it has a era (electronic ratio adapter) if you can figure out which gear ratio would slow the needle down enough to be correct than it's simple using the box. so lets say you have the 3.42 than set the box to 2.xx to slow the speed and make the speedo accurate.
try using the calculation page to try to figure it out. hopefully the box can go to a very high ratio to make it up. email the company to make sure, i'm sure it would work.
Engine: several
Axle/Gears: lots
Somthing like that would work. Would have to figure out just how much variance it could handl. I was thinking more along the line of a home cheap job.
I wasn't seriously considering this, as I really have no use for a speedo that reads to 140, but may play around with a few ideas.
What would a pot in the vss line do to the signal? Would it lower the pulse voltage enough to make it read zero no matter what?
I am not set on even going to the white overlays, was just thinking of things I want to do the next time I pull the column and dash apart. I want to change the ignition switch, mabe the steering wheel and replace a cluster backlight bulb.
Car: 1992 Firebird
Engine: 3.1L V6
The way you explained it made it sound like you wanted to slap on a 140 white gauge face and hope it magically made it a 140 mph gauge.
Engine: several
Axle/Gears: lots
ummm, no. Even i am not that stupid. I did read back to my reply to the original post and kinda see where you get that from though.
I do know some people that are that stupid, possibly an untapped market?
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
even if you were to change the speedometer gear in the tranmission and it read the correct mph on the 140 overlay's.... the odometer would be incorrect. and i dont think its possible to change the parts off the back of the cluster is it?
since we are on this subject, does anyone know how or can point me to a link of how to rebuild one of the 90-92 clusters?
Car: 1987 Firebird
Engine: 355
There are places you can send your speedos to get recalibrated. I dont know why you would pay the $$$ or bother to use up your time with something like that, when you can just swap in a 140mph speedo, and put your overlay on that.
I did this in my car, and it works fine, its a 5 minute swap, and very easy to do. Some say that its off by about +/- 2-3 mph, but i guess most cars are.
Engine: several
Axle/Gears: lots
I never even thought about the odo!!!!
It is electronic, so no gears involved, but kinda hard to get around the odo being 30% off.
Guess that is what I get for thinking.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
what about a mechanically driven speedo, to change from 85mph to 110, or even 145? that direct or need t chang tranny end?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Thirdgen89GTA
Nov 26, 2015 11:04 PM
