87 Firebird Seat Help
Old Jan 16, 2008 | 03:41 PM
monkeyboy13's Avatar
Im gonna be removing all my seats soon. i wanted to know before i go ahead with it, is there any special things i should know,any special steps i should take, is it difficult? and any special tools nessesary. thanks guys.
Old Jan 16, 2008 | 04:02 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: 87 Firebird Seat Help
i think a 14 mm socket wrench is just about all you need and a phillips head screw driver to get the seat belt guides off the front seats to detach them from the seat belts. Other than that, move the front seat foward...get the the covers off the bolt covers with the phillips head screwdriver, then use the 14 mm socket wrench to get the bolt. Do the same for the front after sliding the seat all the way back...that describes the front seats...for the rear, get the bottom cusion out first with the 14 mm bolt in the middle of the bottom cusion on the bottom. Take out both sides then get the bolt out of the hinge on each side with the socket wrench, it's all pretty self explanatory as you get into it. I may have confused 14 mm for 13 in some places but thats about all you'll need...a phillips head screwdriver, a socket wrench and a couple sockets. And this is not hard unless the bolts or screws are rusted. Then you'll have to drill or cut them out accordingly.
Old Jan 16, 2008 | 09:02 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
they are 13mm not 14 mm
Old Jan 16, 2008 | 09:07 PM
84redta's Avatar
i was close
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
MORREALE5
Sep 13, 2015 09:16 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
