Water Damaged Door Panels
Old Jan 16, 2008 | 11:02 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
The door panels are a hard cardboard and the previous owner must have left the window open too many times because the are a bit warped. Anyone come across any good ideas on how to fix them? Can i get them wet again and keep weight on them?, etc...
Old Jan 17, 2008 | 01:18 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Water Damaged Door Panels
Use a blow dryer with the re-wetting method
Most people just buy a thin sheet of plexi and swap over the carpeting trim etc
Stronger lighter and will not warp or distort from moisture or much of anything else
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
