Heater just sucks....
Old Jan 21, 2008 | 04:30 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
My car's heater is horrible. On a cold start it takes 15 minutes before I feel any warm air coming through, and once it starts it is weak. Any other car I ride in if you turn the heater on full blast for just a few minutes it becomes completely unbearable real fast. I can drive around in my thirdgen with the heater on high all day long and while the car does eventually get comfortable on a cold day, it takes forever and is certainly not hot. A drive any less than 25 minutes I can easily see myself not even noticing the heater is on.
Car has 195* t-stat that is new, and operates consistently at a comfortable 190* (CTS reading).
Any tricks to tune up my heater system?
Old Jan 21, 2008 | 05:58 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Re: Heater just sucks....
Try back flushing the heater core, might have some partial blockage. Are the heater hoses getting hot? Maybe you're heater valve or the vacuum tubing is faulty? The vacuum switch on my temp. selector (on the HVAC control panel) went bad and my heater didn't work at all.
Old Jan 21, 2008 | 06:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Easy check.
JamesC
Old Jan 21, 2008 | 06:22 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Could be a dieing blower motor, not pushing enough air passed the heater core. Or a blockage in your vents.
Old Jan 21, 2008 | 06:28 AM
JamesC's Avatar
If "weak" means that the air isn't blowing hard, but is hot, then check the blower motor. If "weak" means that the air isn't hot, then the problem lies elsewhere. Check the hoses at the firewall. It could well be that the core is blocked as TA mentions.
JamesC
Old Feb 15, 2008 | 09:48 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
I would definitely say its more of a problem with the blower motor. High on my car is more like medium - low on other cars.
AC Delete cars only have 3 speeds on the blower motor right?
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
