Steering Column
Old Feb 19, 2008 | 08:16 PM
wmterry89's Avatar
Car: 1983 z28
Engine: carbureted 5.0
Transmission: Muncie 4-speed
Axle/Gears: stock
Steering Column
Can I replace a VATS/airbag steering column in a '90 with one out of an '83?
Also its colapsed, is there anything special I need to do to replace it?
Old Feb 21, 2008 | 12:20 PM
chevhedz28's Avatar
Car: '89 formula,'88 Iroc
Engine: 350,305
Re: Steering Column
It depends on if the column has all the same things as the other column. You will also have to bypass the VATS system or change the igintion lock cylinder and feed the VATS wires up through the column to maintain the VATS. getting the knuckle to come apart can be a little tricky but it's nothing that some penetrating oil and a strong hand can't handle. First and foremost pull the airbag fuse!!!!!! you don't want that thing to deploy while your working on it!!!
Old Feb 21, 2008 | 12:37 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Steering Column
The 90/83 wiring connectors will most likely differ.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
