Accessing Windshield Defrost Vents.
Old Mar 1, 2008 | 05:10 PM
Boaisy's Avatar
Car: 1987 IROC-Z Camaro
Engine: LB9 305ci V8 TPI
This is basically my story from another thread:
Originally Posted by Boaisy
Well since this is the closest post to my question, if you happen to accidentally drop a screw (one of the 4 in the front) and it falls into the defrost vents, how would one go about obtaining the screw? I tried fishing it out with a magnet on a string, but I could not find it. Taking out the dash to get to the vents is an option, but then I would need to know how to get the dash off to access the vents. My car is a 1987 IROC-Z. I have a whole week of spring break to do whatever, and I have already taken the speedometer out because we have to get it fixed. Any help would be greatly appreciated.
Thanks in advance,
Boaisy
I have the dash pad, and the instrument cluster off as mentioned. The screw went inside the windshield defrost vents, and I need to know how to get it out or even remove the vents to get the screw out. In the process, I could even do a good cleaning of the vents. Please help.
Old Mar 1, 2008 | 08:53 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Accessing Windshield Defrost Vents.
Remove the center console, the screw along with whatever else has fallen down there will magically appear.
Old Mar 2, 2008 | 12:18 AM
Pocket's Avatar
Car: 91 Trans Am
Nah, not behind the center console
The defrost ducting is a separate system from the normal vents so removing the dash trim for access wont work
If its not rattling around in there and you're not dead set on removing it, Id leave it
Old Mar 2, 2008 | 03:23 PM
Boaisy's Avatar
If I can get to the vents and get it out, I am more than willing to do what is necessary. I do not want to have a missing screw, or even an odd screw on the dash pad.
Old Mar 3, 2008 | 01:04 PM
Boaisy's Avatar
Got the chance to try this today, and instead of taking out the whole console, though, I was going to switch the radio back to the stock one (we have had a Jensen in it for a few years). When I pulled the Jensen radio out, I found the screw nested on the metal in plain view. I almost went nuts trying to get this screw back XD. Thank you Iron Duke.
Fanatic1074
Oct 2, 2015 03:47 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
