gauge cluster=wanted
Car: 1984 z28 camaro
i need a gauge cluster for my 1984 z28 camaro
all my gauges are going-tach-gas-oil pressure etc..
i wanted to buy it from one of you guys first before i got it from ebay
thanks
thanks
Car: 89 Iroc Convertible
Re: gauge cluster=wanted
I have a cluster from an 84 camaro.It has the tach,gas,temp and volt gauges.Its only missing the speedometer which you could just swap yours into it.Let me know if your interested
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I have a cluster from an 87 manual 305. It has a 5,000 RPM redline on the tach and a 115 MPH speedo. Let me know if you are interested.
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Transmission: 6 Speed/700R4
Axle/Gears: 3.42/2.77 Boo!
Ooh, ooh, I need a cluster as well. I don't care what kind of speedo is in it as long as it works. I don't plan on running 85, much less 115 or 145.
. As long as it's got a V8 tach, going in my IROC.
. As long as it's got a V8 tach, going in my IROC. Trending Topics
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Sorry for the Hijack, I didn't want to start another because of all the repeat threads.
Edit, I found this on Ebay. I can't use it due to the light's but maybe you can use it for your car. It's got the lights instead of the gauges for temp and volts.
http://cgi.ebay.com/ebaymotors/82-89...em290218131714
85 MPH Speedo, fairly cheap though. I've bought few small parts from the seller for my Z28 as well.
