courtesy light troubles
Old Apr 16, 2008 | 02:34 PM
LIDNR2's Avatar
Car: '89 Formula 350, T-Top
Axle/Gears: Stock 3.73's
Can anyone help me? 89 Formula 350. Dome light, and floor lights will not go out. I had to remove the bulbs so they wont drain the battery. I changed the door PIN switches and even replaced the dash dimmer switch. to no avail.
Old Apr 17, 2008 | 05:41 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: courtesy light troubles
this is a very strange situation. I would get a test light and check to see if power is going throug hthe door pin switches even when they are closed, if they are working properly then there is most likely a wire touching behind the dimmer switch that shouldn't be, I think there is a wiring diagram for headlight switch assemblies in the haynes manual.
In firebirds is there a seperate dimmer switch as opposed to camaros that use the headlight switch for both?
Old Apr 17, 2008 | 10:13 AM
LIDNR2's Avatar
The dimmer switch should be the same on both cars. "head light and park lights on a rocker switch with the dimmer and dome on a wheel". I have tried to follow wires with a "short finder" to no avail. the Haynes manual was a help. The door PIN switches are new. The only thing i didn't do yet was remove the A pillar molding and headlinear to see if the dome light wire is rubbing. Thank you, Jim.
Old Apr 17, 2008 | 03:34 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I would still test both door switches just to narrow it down to the dimmer switch
Old Apr 17, 2008 | 07:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If it helps, the door pin switches make a ground connection (-), not a positive connection (+). When door is open, the ground is made for the lamps, when door closed, the ground is disrupted.
Old Apr 17, 2008 | 09:07 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
trace the wires for the lamp and stick a multimeter from the bulb wire to the other wires if you get a voltage across two different wires theres your culprit it couldnt be a short because a short would cause your bulb not to work right?
Old Apr 18, 2008 | 09:01 AM
LIDNR2's Avatar
Thank you all. I'll post back when i find and fix. Thanks again, Jim.
fasteddi
Sep 10, 2015 09:32 AM
andy74
Sep 3, 2015 08:41 AM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
