How do I test dist-tach wire?
Old Apr 18, 2008 | 06:05 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
My tach is dead in my 91 RS. I need to check the wire that leads from the distributor to the tach, but I'm not sure how.
Assuming I have the right connector (the dist is too far back for me to see if the connector is marked), there are about 4 pins in the connector at the tach. In the dash there is the connector that the dash seats onto. It has at least 10 or 12 pins.
I'm guessing I have to figure out the proper pins to check the continuity across. BTW, I suck at electrical stuff and I barely know what the stuff I just said means!
can anybody tell me what I need to do?
Old Apr 19, 2008 | 12:20 AM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Transmission: 6 Speed/700R4
Axle/Gears: 3.42/2.77 Boo!
Re: How do I test dist-tach wire?
Mine was broken in my IROC. If you have the dash out, like I did, you can take a voltmeter and check the connectors for the tach behind the cluster while the car is running. As you rev the voltage will increase. This way you know that the voltage is getting to the gauge and the gauge is dead.
You'll need a wiring guide so you'll know which one is the Tach lead and which one is ground.
Good Luck
Old Apr 19, 2008 | 01:57 AM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
tach wire is white at dizzy and behind dash. it is also ac not dc.its in the 2 wire plug with the pink.its been that way with gm seems like forever. does your tach move at all
Old Apr 19, 2008 | 09:43 AM
Engine: 350 TBI
No the tach doesn't move at all.
Where can i find a wiring guide?
eightsixseven
Dec 16, 2024 01:50 PM
soarestransam
Sep 1, 2015 04:00 PM
Jae992
Aug 27, 2015 09:07 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
