roofing material for sound deadening
Old Apr 19, 2008 | 01:26 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
I'm going to try a roofing product called "blueskin" on my interior for sound deadening. It's made with the exact same stuff as raamat and dynamatt except it is dirt cheap compared to those products. The only diffrence is the companies selling them as "auto inteiror sound deadeners" put tin foil on them, the product im using has a hard but very flexible plastic covering.
Old Apr 19, 2008 | 07:23 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: roofing material for sound deadening
Let us know how it works out. I really want to quiet down my interior, but I can't justify the price of dynomat.
Old Apr 19, 2008 | 08:06 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
When installing windows in a residential home, a product called "window wrap" (brand name) is used. Exact same thing as those pricier products, but runs about $22 for a 200' x 6" roll.
Old Apr 19, 2008 | 08:30 PM
Car: 84 Z28
Engine: carb 305
Ya i can't justify the prices of the brand names either (DYNAMAT, RAAMAT etc..) , its only rubberized asphalt Make sure you get the stuff with low tar content and you might not want to get the stuff with the granules on it becuase on a really hot day the granules can sink through and get all over your carpet and oter stuff.
Old Apr 19, 2008 | 09:54 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
I've compared the roofing product peel n seal, vs the name brand Second Skin, and there is no comparison. The roofing stuff is thinner and doesn't work nearly as well even with double layers. It's also a lot harder to work with.
I'll stick with my expensive name brand that actually works like it was made to, versus something that really doesn't. The higher end products are not the same anyway. They are all rubber with NO tar/asphalt mixture.
Old Apr 20, 2008 | 12:17 PM
Car: 84 Z28
Engine: carb 305
They all have asphalt in them thats the only way they stick. And the roofing material is actually thicker I find.
Old Apr 20, 2008 | 12:28 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Hush mat makes many different thickness of a black foam. I use hush or dynomat with the metal top (for heat) then cover with the foam sheets. it compresses down real easly. great stuff. And at cost dyno and hush realy is cheap. Look around see what you can get. I payed $80 for a case of dynomat with the metal top. About the same on the foam mat. Covered all floors and doors.
Old Apr 20, 2008 | 12:43 PM
Car: 84 Z28
Engine: carb 305
$80??!! I can only find that stuff for like $300-$400 and I dont think it would be engouh to cover the whole interior
MrPackstin
Oct 25, 2017 08:09 PM
LC2 TECH
Oct 13, 2015 11:53 PM
wanext
Oct 6, 2015 12:18 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
