seat belts dont go go back in?
Old Apr 30, 2008 | 06:30 PM
BayWay510's Avatar
Car: 85' Firebird-White/T-Tops
Engine: 2.8
on my 85 firebird the lap belt works but the belt that goes across your chest dosent retracked its on both sides drivers and passenger any ideas how to fix?
Old Apr 30, 2008 | 06:52 PM
greenfire's Avatar
Re: seat belts dont go go back in?
the same thing happened to my driver side seatbelt. what happened is the plastic cover and round gear popped out and the belt wouldn't retract. if your car has t tops you might be able to reach back and put the gear and cover back on, if you don't you will half to figure a way to get in there. i know on the driver side the gear and cover was facing the passenger side hope this helps
Old Apr 30, 2008 | 07:54 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
same thing happened to me, I switched to 4th gen seat belts, made a world of difference!
Old Apr 30, 2008 | 09:19 PM
vette gator's Avatar
Car: 85 Z28
I was able to undo the back of my T-top headliner enough to get a socket wrench in and remove the seat belt from the roof. Mine had the usual problem of the plastic piece coming out. There is a spiral spring inside that plastic cover has to be re-attached to a slot at the end of the roller. To get tension on the belt, I had to turn the white piece several times before putting it back in place. In retrospect, I wish I had given it a few more turns because my belt has a bit less tension than I prefer.
Old Apr 30, 2008 | 09:31 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
My car is an '84 with T-Tops, the plastic cap with the retactor spring on the drivers side is Blue, its on the body sail side. it just pops off enough to release the spring after awhile. its not that hard to fix, but when your turning the plastic part check the tension by pulling on the belt. after I adjusted the tensioner I placed a 2 inch piece of rubber fuel line between the plastic cap and the body. It's never come back out since.
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
scottmoyer
Aug 9, 2015 10:18 PM
