Nordskog Digital Dash questions
Old May 5, 2008 | 06:22 PM
zeitgeist's Avatar
I found a Nordskog digital dash being sold for $300. The dash is in an 82 camaro (like mine) but the sellers car doesn't have the original engine in it (it was a 2.8 but is now a 90 TPI 350, dont know if it matters or not). I swapped my iron duke for a carb'd 350 w/ no computer or emission controls.
I notice on the Nordskog site they list 3 different dashes for 3rd gens. Does anyone know the difference between the 3? If I get the sensors needed, would this dash likely work in my car even though there are no computer controls?
I searched, but I'm really in the dark about digital gauges and all that will be required for them to function correctly. I'm not 100% sure if all I need is the sensors or if its more complicated than that.
Old May 5, 2008 | 08:12 PM
zeitgeist's Avatar
Re: Nordskog Digital Dash questions
Noone?
I guess the assumption I am making is that I can use digital gauges with my car that has no computer, etc, correct? I just have to buy the corresponding sensors to replace the factory ones?
yes/no?
Old May 5, 2008 | 08:28 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i would ask them directly, i believe the 3 different ones was for the 3 different year periods like 82-84 85-89 and 90-92
and sensors are needed if you have idiot lights instead of actual gauges for temp, oil etc...
for different engines thats a specific question for them
Old May 5, 2008 | 08:42 PM
bmccreery's Avatar
Car: 1990 Iroc
I don't see why it wouldn't work. The guages are just looking for a signal, it doesn't care if it has a v-6 or a v-10. As long as you have the sensors you won't have a problem. The shape of the cluster is different between the years but I don't think the voltage the sensors put out changed any. The 90-92 dash needed a different water temp sender wich they supply and you will need a analog to digital speed sensor for your year.
Old May 6, 2008 | 06:33 AM
zeitgeist's Avatar
Thanks.
Old May 7, 2008 | 11:13 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You will need the transducer to convert the mechanical signal of the speedo to a electrical impulse for the digital speedo.Nordskog has this little bugger if the seller doesnt have it.I have an old lense for sale i painted around the readouts so only the digits are visible.
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
