removing a console....83 trans am
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: removing a console....83 trans am
take out the radio take out the shifter plate
lift the console lif and there should be 1-2 bolts holding it to the floor.
also may be a bolt behind the radio holding down in the front
and 1 last bolt in the very center look inside near the shifter after you remove the shifter plate
the whole top of the console should come off after teh torx botls are out
and the bottom piece comes out after all the inner bolts are removed
slides right out a tight fit with the ebrake and where the radio housing touches the dash
just wiggle it and pull out
Hello, Michael
Aug 20, 2015 03:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
