5 Point Harness
Old May 19, 2008 | 02:35 PM
Vinitine's Avatar
Car: "86 Camaro
Engine: 2.8L V6
Transmission: A4
5 Point Harness
Just wondering if anyone has them in their car and what has to be done to install them. What is required to remove old seatbelts and install a 5 point harness?
Old May 19, 2008 | 06:25 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Re: 5 Point Harness
Old May 19, 2008 | 09:55 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: 5 Point Harness
That looks like you don't have a roll bar to hook it up to. How did you mount it behind the seat? I always thought you needed a bar running behind them.
Old May 20, 2008 | 07:11 AM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Re: 5 Point Harness
I was almost positive i was going to do the same in mine. But... you need to install a roll cage, which render your back seats useless. Ive also seen people just connect a beam across the back of the seats and weld it onto the frame or something. But, if your going to do it, just go with a roll cage.
Just remember you want to be pulled back... not down... you don't want to compress your spine. There are no quick build jobs to make this work... it might work.. but it also might make you dead! do it right!
=D Good luck
-Andrew
Old May 20, 2008 | 10:04 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 5 Point Harness
step 1: install 6 point roll bar
step 2: install 5 point harnesses.
if you're not doing step 1, then it's not safe.
Old May 26, 2008 | 08:29 AM
jjlabinski's Avatar
Engine: shinny 350
Re: 5 Point Harness
I designed a set of hoops that mount into T-slots and are secured to the floor via sub frame connectors. I have them designed such that they can slide when the seat needs to be moved and lock up when loaded. Kinda sorta the same whay your shoulder straps work in a standard restrain system. I have design software that allows me to do force and stress analysis and I try not to show pictures of the actual restrain set up because I am in the process of getting it patented.
Jeff
Old Jun 2, 2008 | 11:45 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: 5 Point Harness
Jeff
so you basically made a slider that still has the spinal compression problems? excellent
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
Billy Decker
Sep 4, 2015 03:46 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
