Ugly 1990-92 Steering Wheel Swap
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
So i have a 1990 firebird which has to have the ugly but safe steering wheel in it. i kind of like the three spoke Steering Wheels in the 87 firebird with the bird in the middle. if i swapped would it be a direct swap and what would i have to remove so the air bag doesn't slam me in the face when i try to take the steering wheel off?
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: Ugly 1990-92 Steering Wheel Swap
Pick up a Chilton manual for your car. It has a step by step guide on how to disable the SIR system.
That is the exact swap I did in my 90 Formula.
I replaced the Fulgy airbag wheel with a 3-Spoke wheel out of an 87 Firebird parts car I had at the time. I used a toothpick, and testors model paint to fill in the bird.
It was a direct swap.
Engine: 305 5.0 TBI
looks awesome! hopefully i can find one around here in good shape
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Disconnect the battery first, and you'll be fine. You'll need a steering wheel puller too, you can pick one up for $10 or so at Autozone.
backtothe80s
Sep 5, 2015 12:39 AM
