Modifying ABS headliner to work with C&C t-tops?
Old Jun 5, 2008 | 01:42 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Modifying ABS hardtop headliner to work with C&C t-tops?
Has anyone tried this? My idea is to cut out the t-top openings, and cover it with headliner foam. Is it even possible to cover the ABS liners? I think doing it this way would keep me from having to spray glue a normal headliner board to the roof, for it to stay up.
Old Jun 5, 2008 | 08:25 PM
jts87iroc's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: 4sp auto
Re: Modifying ABS headliner to work with C&C t-tops?
you can. hawks third gen sell's an abs t top covered. i tried to recover my foam board liner but cant get the inside corner's to come out right. i guess i need to get one from hawks.
Old Jun 6, 2008 | 02:22 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I'll probably get one uncovered, I think it would be easier to cut it first, then cover it, rather than trying to carefully cut it and salvage enough slack to wrap up into the t-top openings. I'm trying to avoid having to spray glue the headliner board to the roof like crazy (like C&C did) to keep it from sagging.
Old Jun 6, 2008 | 07:10 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
yea i have done it with my c&c t-tops. u need to make teh headliner flat so cut the side walls of the center part of the abs headliner, match/line it up to your t-tops and have it covered and your good to go.
word of caution:
try to glue or attach the headliner clips for the front
i didnt and the front center dips/sags
jsut be ready to take care of that
goodluck
Old Jun 7, 2008 | 05:36 AM
jts87iroc's Avatar
Car: 87 iroc
Engine: 305 tpi
the on from hawks is cut out and covered when you buy it comes with new speaker covers and sun visors.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
