Vacuum tubing
Old Jun 10, 2008 | 07:31 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
Vacuum tubing
I have a couple of heater control units on hand but I have never been able to get enough of the multi colored tubing to reach where they need to go on none of these.Has anyone tried splicing pieces of these things together?I am not going to have A/C so do I even need them?I am not even sure where I am going to pick up vacuum off the engine to operate them any way.Maybe a small port of the carb?
Old Jun 10, 2008 | 07:45 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Re: Vacuum tubing
you are right about the carb. look on the back of it.
Old Jun 10, 2008 | 07:54 PM
wvabreeze's Avatar
Re: Vacuum tubing
Thanks,I don't remember any small ports on back only for the brake booster.It's an older Holley,not many ports on it.I have the wife looking around at the hospital where she works for somthing to splice the tubes together with,I'm thinking something like IV attachments or maybe even cut up some large hypodermic needles or something.
Old Jun 10, 2008 | 08:28 PM
wingers383's Avatar
Car: 92 Chevy Camaro
Engine: SBC 383
Re: Vacuum tubing
Go to autozone and get a vacume tube splice kit for a couple of bucks and fix your problem!! It has several t's and reducers in it. I think it's in the help section.
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: Vacuum tubing
You should be able to pick up vacuum splices at a Checker or Autozone. Just a piece of plastic that both tubes slide onto, and then two little clamps for each tube end.
Edit: NINJA'd!
Old Jun 10, 2008 | 09:58 PM
wvabreeze's Avatar
Re: Vacuum tubing
Thanks guys,I have seen the splice kits for underhood type vacuum hoses but the silicone ones on the HVAC controls are tiny.I probably overlooked them before,wasn't looking for ones this small before.
Old Jun 11, 2008 | 05:55 AM
hot92RS's Avatar
Car: 92 Z-28
Re: Vacuum tubing
I agree-get ones from the parts store not the hospital. very inexpensive.
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
