Odd Window motor problem
Old Jun 30, 2008 | 11:01 AM
tommygun's Avatar
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
I have a passenger's side window motor in my 92 Formula that goes up and down in increments. It will go up or down about 5 inches, then I have to wait about 20 seconds to hit the switch again to get it to go another 1/4 or 1/2". I pulled the switch and checked for loose connections/cleaned it with CRC/relubed with dielectric grease. Same problem. Is this most likely a motor, or some kind of hidden relay?
Old Jun 30, 2008 | 07:33 PM
damage31's Avatar
Re: Odd Window motor problem
Sounds like what happened to me...My window would go down but would only go back up in small increments before I would have to wait to try it again.
If I'm not mistaken, somewhere in the motor is a self resetting fuse that gets tripped by excessive current draw. The only option is to replace the motor. I got mine from NAPA for like $30-$60 with a lifetime warranty.
In my camaro the motors are held in with 3 or 4 large rivets..I had to buy a special rivet tool as a hand rivet tool was not enough to pull the pin to get the rivets to stay. Oh yeah, and watch out for the spring that helps the motor...I almost lost a finger when my pass side spring sprung on me... I never was able to get that spring back in again, it was to hard.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
stalkier
Aug 13, 2015 12:59 PM
