Cheap gauge cluster
Old Jul 27, 2008 | 02:32 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Cheap gauge cluster
My gauges have finally stood on my last nerve. The speedo quit working (it reads then stops, reads then stops) and the needle fell off the temp gauge. Everything else works as well as can be expected from stock gauges, but I'm ready to upgrade. I don't have a lot of money though. Covan's Classics sells a nice looking unit but I can't afford $550-$800 for this stuff. Is there anywhere that sells something like the Covan's classics unit with less expesive gauges? I may be able to swing $200. This may be an impossible budget for this project, but I'm going to research it anyway. Can you guys give me a plac to start?
Old Jul 27, 2008 | 04:59 PM
runfan1600's Avatar
Car: 1987 Iroc Z
Engine: was 305, now a 350 crate
Re: Cheap gauge cluster
go to your local junk yard and see if you can find a 3rd Gen and take its cluster.
Old Jul 27, 2008 | 06:36 PM
RazorN8's Avatar
Car: 1987 camaro
I don't want stock gauges anymore. I will probably end up doing some fab work, but what are some dependable low cost gauges and where can I ge them?
Old Jul 27, 2008 | 07:34 PM
runfan1600's Avatar
Car: 1987 Iroc Z
Ohhh...yea i been looking all over for something like thta other then hawks third gen with the cluster that is $400+ thats why im going with a 4th gen dash and console swap just need to find out were to buy complete sets. srry. try and do a search in the forms
Old Jul 27, 2008 | 08:01 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
200$ will not be enough to replace all your gauges with aftermarket ones.
All you can do is go with some junkyard parts.
Old Jul 28, 2008 | 05:31 PM
RazorN8's Avatar
Car: 1987 camaro
What do you think would be the cheapest that I could do this project?
Old Jul 28, 2008 | 08:57 PM
runfan1600's Avatar
Car: 1987 Iroc Z
http://www.youngsfbody.com/inc/sdetail/32297
codeysabatini
Sep 20, 2015 11:36 AM
Trevor Tarry
Sep 15, 2015 02:04 AM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
90formulaVortec
Sep 8, 2015 12:42 AM
