91 z28 shift indicator
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
can anyone show me a picture of what the gear indicator is supposed to look like on a 91z28 auto car. just bought a 91 z28 and the indicator shows neutral when in reverse and so forth so im sure it needs some adjustment trouble it it has 2 "D"'s im sure one is overdrive and the other is not is the cover for a 91 supposed to have both "D"'s thanks for any help in advance
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 91 z28 shift indicator
Yes, there are 2 "D's" on the pattern, the upper one is OD, and the lower one is D.
thanks for conforming i figured such, now i must figure why the shifter is off when in reverse it shows neutral, and i can go through every gear but cannot get into 1st gear, shifter doesnt allow and will not go down so far thanks 4 the help
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
When you move the actual shifter, does the transmission go into gear in the order shown on the shift plate but the red mark on the plate is not in the right spot? If that is the case then the shift plate is probably broken somehow.
TheTraut88
Sep 7, 2015 05:22 PM
