Auto Shift Knob
Old Aug 5, 2008 | 12:33 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Transmission: Auto 700R-4
Auto Shift ****
Hey,
I have a Auto 1990 RS and need to replace the shift plate but I can't get the **** off the shift assembly in order to both remove the old shift plate and install the new one....
Does anyone have any suggestions?
Old Aug 5, 2008 | 12:57 PM
snardos's Avatar
Car: 1992 camaro z28
Axle/Gears: 2.73:1
Re: Auto Shift ****
There is a metal staple type fastener that holds the shift **** onto the shaft. If you look on the front of the leather area there should be a piece of metal sticking out. Get a screwdriver between the leather and the metal and pry it out and then pull the assembly off the shaft.
Old Aug 6, 2008 | 01:17 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: Auto Shift ****
The staple faces the radio and is easy to get out. A small flathead will do the trick.
Old Aug 7, 2008 | 08:18 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Re: Auto Shift ****
I'll try that. I know what you're talking about but when I looked there (before I asked this question) there wasn't a staple there was a hole there and inside was a plastic looking piece that doesn't seem to move. I'v tried twisting or pulling on the **** but it doesn't give. I'll have to give another look at that particular area.
Old Aug 14, 2008 | 08:52 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Re: Auto Shift ****
Just wanted to let you know I got the thing off. I was trying to twist it, but then decided to pull straight up and it came off. There was no staple in it, I guess it is just missing,
Thanks for the help
Old Aug 14, 2008 | 09:03 PM
Axle/Gears: Posi
Re: Auto Shift ****
No problem. You can find that staple on your next trip to the j yards. Regals have them also.
junior419
Apr 7, 2025 11:35 AM
F-body driver
Mar 6, 2023 11:44 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
armybyrd
Sep 16, 2015 07:00 AM
