1988 IROC WITH 1992 GAUGES
Old Aug 9, 2008 | 07:54 PM
kevin88iroc's Avatar
Car: 1988 irocz
Engine: 305 tpi
Transmission: t5
QUICK LITTLE RUNDOWN. I PURCHASED A 1988 IROC Z WHICH WAS ORIGINALY EQUIPED WITH A CARBORATED 305 AND AN AUTOMATIC TRANS WITH T-TOPS. THE PREVIOUS OWNER SWAPPED OUT THE TRANS FOR A T-5 AND REBUILT THE MOTOR. NOW IT'S 30 OVER, NICE COMP CAM, NICE HEADERS AND REBUILT HEADS. THE MOTOR IS, I BELIEVE, BLUEPRINTED FOR 7200 RPM (NOT SURE WHY ON A 305 WITH A T-5 BUT ANYWAYS). HE BUILT THE MOTOR AND DID THE SWAP NEARLY 2 YEARS AGO AND NEVER GOT THE CAR RUNNING. THE 1988 TPI AND COMPUTER WERE ADDED BUT HE NEVER GOT THE NEW FUEL PUMP WORKING. LONG STORY SHORT, I BOUGHT IT ONE WEEK AGO AND YANKED THE MOTOR AND TRANS FOR NEW PAINT AND A CHECK OF HIS WORK. TWO QUESTIONS, ONE, HAS ANYONE EVER SWAPPED OUT A 1992 GAUGE CLUSTER INTO A 1988 IROC (OR SIMILAR YEAR) AND DOES ANYONE HAVE A CLEAR UNDERSTANDING OF A STOCK WIRING HARNESS? I KNOW, REPLACE IT, BUT I CANT AND WONT (ITS A WIFE THING).
Old Aug 9, 2008 | 08:56 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: 1988 IROC WITH 1992 GAUGES
Best thing you can do is buy a 1988 Camaro Service Manual, it'll help tremendously on your wiring issues.
I swapped a 88 TBI system in my 85 Trans Am and I don't know how I got by without mine. I ended up buying the 88 Camaro service manual first (which I still have) and got the Firebird version a little while after.
There's not much to the fuel pump system and relays, basically a signal comes from the ecm to the relay and back to the pump...that manual covers this.
Old Aug 9, 2008 | 09:39 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
IMHO your opening up a can of worms. You need to deal with vats, airbag, dash swap, electronic instead of mechanical etc.
Old Aug 10, 2008 | 06:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Since the two clusters, mechanical 82-89 and electric 90-92, are shaped differently, swapping would require heavy modification.
JamesC
Old Aug 10, 2008 | 07:57 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
It has been done before, I don't remember who did it but if you search you should be able to find it. However, for the wiring you may be better off using a painless harness because you're carbed. The stock 91-92 harnesses are speed density (minus the TBI). The painless harness would probably work much better for you, then you get all brand new wiring too.
Vintageracer
Jan 10, 2020 05:33 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
