OER Interior Paint
Old Aug 17, 2008 | 02:50 PM
barristerjim's Avatar
Car: 87 IROC-Z
Engine: 305 TPI (LB9)
OER Interior Paint
I had my seatbelts replaced after learning of the recall. Here's the link in case any of you haven't seen it. https://www.thirdgen.org/camaro-seatbelt-recall. My problem is that my car is white with a red interior. The Chevrolet dealer informed that the seatbelt receivers are no longer available in red, and that the best they could do would be to get me gray. The service tech who installed them also has a Camaro and recommended that I get the OER interior paint in carmine red if I wanted to match the seatbelts with the rest of my interior. I've read a lot of bad reviews of OER products and had a bad experience with their weatherstripping, so I'm a little leery about using their paint. They don't look bad in gray but I would like to make them red if possible but I also don't want to make things worse if the OER paint isn't any good. Has anyone used OER interior paint before and with what results? Thanks in advance for your help.
Old Aug 17, 2008 | 07:40 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Re: OER Interior Paint
well personally i used a black interior paint sold in advance auto parts and had good luck with it. i did my entire interior and looks amazing
Old Aug 17, 2008 | 08:11 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Look for SEM "Firethorn" red plastic paint, it comes the closest to carmine in my opinion.
Old Aug 17, 2008 | 09:21 PM
Car: 87 IROC-Z
Thanks for your responses. I want to try and match it up as close as possible so I'll check out the SEM Firethorn.
Old Mar 7, 2009 | 01:09 AM
VRROOMmaster's Avatar
Car: 1970 SS
Transmission: TH350
Axle/Gears: 12 Bolt Posi 373
I've used the OER paint. Great stuff. Covers well. Will not peel off. Some of the best paint on the market.
Vintageracer
Jan 10, 2020 05:33 PM
Hawk312
Aug 22, 2017 08:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
neekolzun
Aug 24, 2015 04:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
