Just put new weatherstriping on and can now barely close my door
Old Sep 5, 2008 | 05:23 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I just put all new soft seal weatherstripping on my doors and roof rail. When i put the new stripping on my doors and test colsed them i couldn't really get the door closed with out really shutting it hard or giving it a good bump. Then i put the roof rail stripping on and it's even worse. My window wont roll down from the inside because of all the pressure from the stripping pushing against it.
Is there a way to adjust the window to bring it out some so there isn't so much pressure against it?
Old Sep 5, 2008 | 10:55 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Re: Just put new weatherstriping on and can now barely close my door
Which weatherstrips did you buy?
Old Sep 6, 2008 | 02:40 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Have you adjusted your door striker? How about hinge pins and bushings? If the door fit well before with the old crushed and worn out weatherstrip, then the new ones will fit tight.
Old Sep 6, 2008 | 08:11 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i got the metro kit its both doors and the hatch and for about a week or two i could barely shut my doors but its fine now shuts perfect
Old Sep 6, 2008 | 11:05 AM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
it says in his post "soft seal" so Im guessing its the weatherstip from Soff Seal...I havent bought anything from them but Ive read on the boards that weatherstipping from GM is the only way to go...
Old Sep 6, 2008 | 11:46 AM
Brennan's Avatar
thats true but at half the cost i got my metro seals and i have no complaints only that the molded caps on the ends are not even close to oem
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
BlackTopKing
Aug 19, 2015 12:13 PM
92camaroJoe
Aug 13, 2015 06:07 AM
BrianI
Aug 9, 2015 11:52 AM
