Pilot Steering wheel hub not seating?
Old Sep 29, 2008 | 04:34 PM
SpeedJunkie's Avatar
Car: 88 IROC
I tried to install the hub #SW-900 on my 88 camaro steering column but it doesnt seem to slide on the splines to well or its getting stuck on the smooth lined part after the splines. I mean I could mash it on and I think its on the splines and not damaging them at all it just seems real tight.
Anyone else have this problem? If I leave it as far as it kinda goes you can see the lock ring for the steering wheel lock. About a 1/3 inch gap between the plactic round Pilot hub cover and the actual steerin column
Old Oct 5, 2008 | 08:31 PM
Car: 88 IROC
Re: Pilot Steering wheel hub not seating?
Anyone got an idea on this? I could pound it on with a hammer but really dont want to
Old Oct 5, 2008 | 09:40 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
are you putting a grant wheel on?
if so the is a small spacer like washer that go on the hub first, if you do not have this when you tighten down the wheel it will bind and be hard to turn.
i have no idea if this is the prob you are having from what you tried to explain but this happens to a lot of first time installs.
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Sep 17, 2015 12:22 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
