Steering column
Old Oct 28, 2008 | 06:35 PM
TAdude's Avatar
Steering column
Noob here.. I need a tilt steering column repair kit for my '91 TA but I noticed all the kits out there say they repair 1982 to 1990.
Will these earlier kits work on my car or is there something way different about the 91s and 92s??
Jeff
Old Oct 29, 2008 | 01:53 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: Steering column
I had the same thing come up the other day too. Does anyone know what the difference is between a '90 and '91 column?
Old Oct 31, 2008 | 06:13 PM
Car: 1989 IROC
Engine: 305TPI
Re: Steering column
OK so it looks like the column I have is out of a '92 and the front of the housing is about 1/2 an inch longer then the column in my '89 IROC. (I'm guessing for extra airbag guts) SO the repair kits don't look like they will work for '91 or '92 but probably not for '90 either.
Old Nov 1, 2008 | 02:18 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Steering column
Ok, 82-89 = same collumn. 90-92 = airbag collumn. The GM dealer has them. I replaced the cam and lock cylander in my 90 rs recently. The major differences are length and girth (The 90-92 collumn has a narrower steering shaft) It is for the airbag that GM redesigned the collumn. (For airbag contact ring) PM me if you need help.
Good luck!
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
