a-pillar pod weatherstripping?
Old Nov 7, 2008 | 01:23 AM
Kandied91z's Avatar
need some suggestions on replacing that little strip on either side of the a pillars. mine has started to crack and wear. can't seem to find a new replacement from the standard seal companies.
Old Nov 7, 2008 | 01:35 AM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Re: a-pillar pod weatherstripping?
I've looked also and haven't found anything yet. Mine is so brittle it practically crumbles if you try to touch it.
Old Nov 7, 2008 | 10:03 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I think you can buy it from Jc whitney. Its just a common L shaped seal.
Old Nov 8, 2008 | 06:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Find one in good condition at a bone yard. Strip it from the pillar, reglue to yours. Once dry, liberally douse it with silicone to guard against its drying out and cracking. Worked well for me. You might check page 3 of the following link:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Nov 20, 2008 | 12:11 AM
Kandied91z's Avatar
thank you for the suggestion. thirdgens and junkyards are a rare combination here in michigan
Frozer!!!
Jan 19, 2024 04:55 PM
aharvel50
Sep 21, 2015 07:31 PM
arod231
Aug 16, 2015 02:51 PM
89lsc
Aug 14, 2015 04:58 PM
WECoyote
Aftermarket Product Review
35
Apr 21, 2002 09:41 PM
