help removing instrumeant panel?
Old Nov 7, 2008 | 12:20 PM
3rdGenIrocZ's Avatar
So im wanting to put new lights in my instrumeant panel so my speedo and all that stuff lights up better. I know how to remove everything down to the actual metal plateing of the gauges. i just dont know how to get the lights out from the bottom of the panel? any1 know?
Old Nov 7, 2008 | 12:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: help removing instrumeant panel?
Once the cluster is removed, you'll have access to the bulbs, which simply twist out.
https://www.thirdgen.org/forums/atta...-pics-bulb.jpg
JamesC
Old Nov 9, 2008 | 02:13 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
ONCE THE LITTLE TORXHEAD TRIM SCREWS ARE REMOVED FROM THE BEZEL, YOU'LL FIND ANOTHER SET THAT WILL REMOVE A FILLER PLATE AND THE CLEAR PANEL. THEN THE INDIVIDUAL GAUGES CAN BE REMOVED. THEN THE BULBS ARE ROGHT THERE. THE FRUSTRATING PART WILL BE THAT SOME OF THE BULB HOLDERS ARE HARD TO GET FAT FINGERS INTO(EXPERIENCE TALKING) AND THE GREEN DISKS FOR YOUR BLINKERS FALL OUT.
Old Nov 9, 2008 | 03:30 PM
JamesC's Avatar
As I mention above, removing the cluster from the dash will simplify bulb removal.
JamesC
Old Nov 11, 2008 | 10:32 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
JamesC has the right idea. It is much simpler to remove the cluster and then replace the bulbs. No "little fingers" needed.
Vintageracer
Jan 10, 2020 05:33 PM
tcflint
Sep 14, 2015 04:55 AM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
