Seat Covers
Old Nov 14, 2008 | 03:53 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Seat Covers
How hard is it to install the seat covers in a 83 TA. I saw the OEM in
Classic Ind. for $379.00 a set. Never done it before.
Al
Old Nov 14, 2008 | 06:09 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Seat Covers
just my thoughts , i would take it to a good local shop . i tried once and screwed up . they fixed it up and made it look good . i know mechanic's but not upholstery . just an opinion from an old phart . good luck .
Old Nov 15, 2008 | 02:53 AM
jimmyj2000's Avatar
Car: 88 Formula 350
Engine: l98
Axle/Gears: 3.23 9-Bolt
Re: Seat Covers
I did it to my last Camaro, and I did not think that it was too hard at all actually. There is really not much to it. If you look, there may be some videos on youtube or google or something that will kind of guide you through the process.
Basically, it goes like this: Take your seats apart(completely, meaning remove seat tracks, separate upper and lower parts,etc), cut the hog rings holding the old upholstery on, slip new upholstery on (Tip: on the seat backs, it helps to turn the cover inside out and roll it down the piece), put seats back together. Another tip: I went to the hardware store and bought a pair of hog ring pliers (about ten bucks), because I was not aware that the cover kit came with one, and you may want to do the same because the one in the kit is crap and mine ended up in the garbage.
HP52TA
Feb 3, 2018 10:51 PM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
