4th gen headlight switch wont work.... please help!
Old Dec 23, 2008 | 03:11 PM
solaris_vii's Avatar
Car: 1997 z28
Engine: lt1
Transmission: t56
im currently doing the fourth gen interior swap in my 85 iroc to a 2002 ebony camaro. things are goin along all right but i just cant seem to get the dash lights to work with the fourth gen headlight switch. it will work the domelight the headlights and parking lights, but not the dash lights. anyone who has done this swap and can tell me how they wired it to work would be GREATLY appreciated! thanks
Old Dec 25, 2008 | 11:41 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: 4th gen headlight switch wont work.... please help!
Gray is the wire for all the dash lights. It's easy as pie. Also check fuses.
Old Dec 25, 2008 | 04:40 PM
Car: 1997 z28
Engine: lt1
Transmission: t56
but what does the gray go to? ive got one gray going to another gray which does the interior dome lights, but i dont know where the other gray goes i think green but that still doesnt work. ill have to check the fuses i guess. thanks for your help
Old Dec 25, 2008 | 05:28 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Gray or light gray (cant remember off hand) controls all dash illumination on nearly all GM cars from the 80s and 90s. Its the same color as you used to wire the cluster up.
Old Dec 26, 2008 | 06:54 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Just to make sure your dash lights are working, I would take the grey wire from the 4th gen cluster and run it to a pink or orange wire, (orange is constant hot) (pink is hot w/ ignition) just to see if it is working.
Old Dec 27, 2008 | 02:05 PM
Car: 1997 z28
Engine: lt1
Transmission: t56
thanks for the tip, ill try it tomorow morning
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
cam-mike
Aug 24, 2015 07:23 AM
tnrednneck
Aug 13, 2015 08:57 AM
