SEM PAINT FOR INTERIOR PLASTICS?
Old Jan 5, 2009 | 09:55 PM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
I was just curious if any of you have used the SEM paint to paint your inner plastics? I have grey interior and want it Knight Rider black...just curious if you all had good luck with SEM?
Oh yeah, and where to get it locally i cannot find it? I live in Polk County FL area.
Old Jan 5, 2009 | 11:39 PM
ILUVMY89's Avatar
Re: SEM PAINT FOR INTERIOR PLASTICS?
SEM IS THE BEST USE NOTHING ELSE I USED ONE CAN TO COVER ALL MY PLASTICS IN MY RS THATS ALL I USE
Old Jan 6, 2009 | 09:20 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i wanted just wat you wanted. i did all my plasitc panels over a yr ago in the summertime. i let the paint bake in the sun.
i used sem products all the way
so far nothing has peeled off but... you got do many many steps to make sure you only have to paint these things once
i steam cleaned the panels one by one. washed them with soap
i used 400 grit sand paper and gently scuffed the panels so paint has fresh plastic groves to bite onto
used automotive alchohol cleaner with lint free micro fiber rags to do a final clean wipe of the panels
used 2 coats of promoter to help the paint stick then painted the panels jet black.
came out very nice.
take your time find a nice sunny day to do it outside.
and do one panel at a time, cannot rush this
goodluck
Old Jan 12, 2009 | 11:49 AM
redfivexw's Avatar
Sem does work very well, prep is everything though. Make sure whatever you are doing is very clean
Old Jan 13, 2009 | 12:11 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Bobby_80s is giving very good advice! The prep work is sooo important! While I didn't go as far as he did, I scrubbed everything well with a degreasing soap and warm water using a nylon bristle brush. I used VHT plastic paint in black and it turned out very well... it's a very good match to the original 3rd gen black. I also used their vinyl dye that comes in an aresol can for the firebird deluxe "gta" door panels and it has held up well for several years now, even on the rubber-like interior door handles!
Old Jan 14, 2009 | 06:54 AM
Phantom1016's Avatar
You have any pics?
Old Jan 14, 2009 | 07:34 AM
Bobby_80s's Avatar
Axle/Gears: no idea
go to my post which has my project from start-present still adding to it but let me know on the post what u think, hope this helps. on there are before and after pics of my painting interior panels and much more.
https://www.thirdgen.org/forums/body...=trans+am+1986
if the link doesnt work just go to search and search for
my 1986 trans am take a look
and you'll know its mine if its posted by Bobby_80s
thanks
Old Jan 14, 2009 | 12:10 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
here is a link to my thread about dying my door panels:
https://www.thirdgen.org/forums/body...ht=door+panels
And here are some of the plastic pieces that I've repainted:
https://www.thirdgen.org/forums/body...ght=rings+trim
The door sills had the paint scrape off in some spots due to my doors sagging. The guage trim has held up very well for a couple years with no problems. I also suggest that you let them sit for a couple days after painting before doing any serious handling or installation. They will also have some "dust" to wipe off. I wiped mine with a damp rag and got a lot of black dust off of them before installing.
Old Jan 14, 2009 | 12:22 PM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Transmission: 4 sp. Auto-4L60
One note, though...all the plastics in KITT were tan. Just the vinyl and console are black.
Old Nov 10, 2009 | 04:50 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
which SEM product is the best to use?
Old Nov 11, 2009 | 01:50 PM
1Aauto's Avatar
Former Sponsor
X2 SEM is great stuff
Old Nov 11, 2009 | 02:14 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
SEM Color Coat line, get the prep sprays too
Old Nov 16, 2009 | 05:59 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I just used SEM Landau black (Item# 15013) to respray my A-pillar trim piece. This black matches stock color really well. I just washed trim piece with simple green and then sprayed a couple coats on. Was around $13 for a can at Sherwin Williams Automotive store.
Old Nov 17, 2009 | 01:39 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
Dose anyone know what sem color number to use for the interior gray trim in a firebird?
Old Nov 18, 2009 | 06:56 PM
Gfezz's Avatar
I used Sem color coat Thomas Bus Grey over grey panels and was very close match...
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
g.l.mos
Aug 22, 2015 12:02 AM
