camaro gauge cluster compatability????
Old Jan 8, 2009 | 09:41 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i have a 1987 base camaro with a basic gauge cluster with idiot lights
i want real gauges not lights
i can replace the sensors no probelm
but what should i look for on ebay for a replacement gauge cluster?
what years or versions are compatible?
my guages don't have rpm but is the wireing there in teh connector jsut not being used?
and would the wiring connectors in teh back of the cluster stay teh same or have to change as well
any insight would be great help guys cuz i have no clue
Old Jan 8, 2009 | 11:21 AM
Bobby_80s's Avatar
Axle/Gears: no idea
Re: camaro gauge cluster compatability????
ok i did soem research from what i gather:
82-89 clusters r plug n play, the base camaro already has a tach wire there so thats great you can basically drop an iroc cluster into a base camaro as long as its from 82-92
all i gota do is drop a cluster i want in and change the sending units
the 90 or 91-92 for sure had electronic speedos and everything is completely different. nto a direct swap at all
now if anyone wants t o clarify my findings or add to it or correct me please do
Old Jan 8, 2009 | 12:08 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
There are differences in the 82-89 clusters,....... If you use one from an 82-84 in your 87 than there will be a problem with the E-Barake warning light and one of the cluster "backlights".
If your car is a V6 than be sure the cluster is from a V6 too! ( To more specific: the Tachometer is specific to the engine -but the rest of the cluster will work fine. ) V6 Tachometers show 40-80 Oil Pressure and V8 Tach show 30/60 Oil Pressure.
Once you install the gauge cluster ( with correct Tach ) all you will need to do is to install the proper sending units on the engine for the gauges to work.
I've got a good V6 cluster available:
Old Jan 8, 2009 | 12:31 PM
Bobby_80s's Avatar
Axle/Gears: no idea
perfect!!!!
what year is your car from?
i sent you a PM.
get back to me when you can thanks
Old Jan 8, 2009 | 07:09 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
wait.. i just bought a 145 mph hour cluster out of an 87 for my 88. my 88 came stock with a 115 mph. when i bought the car the tach was completely off. it read like 5000 rpm when idleing (spelling?) and the speedo didnt work at all. changed the speedo cable and it still didnt work so i just decided to change the whole cluster out. im going to install it tomorrow, but i thought it was just a direct swap? didnt know you had to change the sending units on the engine as well?? i bought this car about 2 months ago and the guy i bought it from swapped the engine for a 350 tbi. it had a 305 tbi. but theres lots of wires just dangling around and everything. it runs great. starts right up, drives fine. but are these sending units going to be in the same place as if it was a 305? im reallly sorry just verrrrry confused on the whole sending unit thing. if somebody could please verify it would be great. thanks!
Old Jan 8, 2009 | 07:56 PM
John in RI's Avatar
MichaelSparks88: He's only got Warning lights in his cluster right now...... your car sounds like it originally had gauges in it. Warning light clusters have "switches" and gauge clusters use "sending units".
Old Jan 8, 2009 | 08:00 PM
Ca[maro]88's Avatar
ohhh sorry bout that lol
thanks John. had me for a scare there lol.
Old Jan 8, 2009 | 08:18 PM
Ca[maro]88's Avatar
hey John, sorry to bother you but you seem to obviously know more than i do. you think you can check out my thread and tell me what you think? i really need some help on something. please remember this was posted before you told me about the sending units.
https://www.thirdgen.org/forums/elec...wap-sorry.html
Old Jan 26, 2009 | 07:30 PM
87camarogirl's Avatar
Car: 87 Camaro
Engine: 2.8 fuel injection
Transmission: 5spd
from what i've gathered in this thread, theres a wire already set up for the Tachometer..
That being said, if i get an aftermarket (dash mount) tach, can i simply connect the wires? I have a 5 speed 87 2.8l v6 and instead of a tach i have a giant gas gauge.
Old Jan 26, 2009 | 08:50 PM
Bobby_80s's Avatar
Axle/Gears: no idea
if you can find the wire in the connectors...
run a tap off of it and send to the aftermarket gauge.
im keeping my 5spd as stock as possible so i boguht a v6 camaro cluster from and RS or up model that has all the neeeded gauges
Old Jan 27, 2009 | 08:22 AM
vahn401's Avatar
Ok, I'm confused and need help. I have an 86' Iroc with the 85mph top speed cluster, and then I have another 86 Iroc parts car with the 145mph top speed cluster. The MPH limit is the only difference I can see between the 2 clusters. Can I simply take the 145mph cluster and repace the 85mph cluster, and everything will work? Or do I have to replace other parts in the car? Any help would be great.
Old Jan 27, 2009 | 08:55 AM
John in RI's Avatar
86 cluster with 85 speedo and full gauges
86 cluster with 145 speedo and full gauges
This is a "direct swap" !
P.S. You will obviously no longer have the correct odometer reading for your car. The odometer dial can easily be re-set ( pulled from one speedo and placed into the replacement speedo ) but that may or may not be "legal" where you live.
Old Jan 27, 2009 | 09:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link if your trip odometer doesn't work:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Jan 27, 2009 | 09:09 AM
John in RI's Avatar
You could install a complete factory V6 cluster for about the same cost and have a working Tach as soon as it was plugged in.... Volts should work too. ( you could buy the TEMP and Oil Pressure sensors later if you wanted them to work - they are pretty cheap.)
If you simply prefer to have an externally mounted Tachometer......... The Tach wire can be found at the distributor and run into the passenger compartment.
Old Jan 27, 2009 | 09:19 AM
vahn401's Avatar
Thank you for the response, thats the beauty, there is only a 1k mile difference between these 2 clusters, which is the only reason why I considered it.
Old Jan 27, 2009 | 09:58 AM
John in RI's Avatar
WOW !
How Lucky are you !!!
Old Jan 27, 2009 | 10:07 AM
vahn401's Avatar
I have had the parts car sitting around for a few years, and it was parked with 103k on it, and when I picked up my recent IROC it had 101k, and I barely put any miles on it this past summer due to Carb issues. Now that the mileage is close, I'm looking into it.
Old Oct 13, 2009 | 07:08 PM
Feroluce's Avatar
Car: 84 Camaro T-top
Engine: 350cu Interceptor
ok heres one my car is an 84 w/ the double needle gauge, was a 2.8 v6, now its a 350v8, and i want to put in a 115mph cluster w/ tach from a 89 305 will the tach work?
Old Jan 10, 2010 | 01:54 PM
Snoopius's Avatar
Car: 2003 Mustang GT
Engine: 4.6L SOHC
Transmission: Tremec 3650 (5spd)
So then would a cluster from an 87 iroc work alright in my 84 z28?
(Sorry to reopen this)
Old Jan 16, 2010 | 09:24 PM
minitaz's Avatar
Car: 1987 Camaro
Engine: 2.8 V6
I have replaced the cluster in my 87 Camaro V6, Tach and speedometer, and altmeter working fine. Do I need to replace the coolant temp sensor or coolant temp sending unit. The sensor is 2 wires on the front of the intake and the sender has one wire and I am not sure of the local.
Old Feb 5, 2011 | 09:52 PM
2ndchevy's Avatar
So is it possible to swap a temperature gauge from an '84 305 tbi into an '86 305 tpi. I swapped one from a berlinetta into an iroc, but it rises very quickly and the car doesn't seem like it's overheating.
Old Mar 7, 2011 | 10:03 AM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
can I just buy a whole new cluster that includes a tach for my 85? It currently doesnt have one an its a 305 Carb.
Old Mar 7, 2011 | 10:09 AM
JamesC's Avatar
https://www.thirdgen.org/gauges
JamesC
Old Dec 28, 2012 | 11:30 PM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
Can you put a berlinetta gauge cluster in a 90-92 camaro? How would it be done?
Old Dec 28, 2012 | 11:38 PM
Bobby_80s's Avatar
Axle/Gears: no idea
probably need to swap apsolutley everything! basically take the entire dash and swap it. all electronics and car computer but then theres compatibility issues between the dash and the engine which is another mess i can't really concieve of at the moment and hopefully the engine is close enough in type and year that the computer will be compatible but from early 80s to early 90s your probably going to have to swap out engines and at that point.....
just buy a damn berlinetta dirt cheap and be done with it
Old Dec 29, 2012 | 12:04 AM
Car: 1986 Camaro
Axle/Gears: 411
Damn I agree that is way too much bs lol I seen one in the scrap yard today and i kicked myself in the *** for not taking it so I'm going to go back tomorrow morning and get it then I guess just sell it haha thanks for the info.
Old Dec 29, 2012 | 12:45 AM
Bobby_80s's Avatar
Axle/Gears: no idea
junk yard is good for parts. especially for berlinettas. but i would try to find an already running berlinetta and fix that one up.
problem is, those cars were built with economy and luxury in mind and not the speed and performance we expect from something like an iroc.
if you want power plus the cool electronic dash. best bang for buck in my opinion is the late 80s Pontiac firebird GTA's!!!!!!
Old Dec 29, 2012 | 01:59 AM
Car: 1986 Camaro
Axle/Gears: 411
Yeah I see what you're saying. I was just thinking of pulling out the cluster and selling it on craigslist for a few more bucks or maybe trade it for something. I just seen it today and wanted to know exactly what needed to be done to swap it but after hearing all that i think I'm better off sticking with my 145 cluster lol
Old Aug 26, 2013 | 11:28 AM
CamaroPaul's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6 Multi-Port Fuel Injection
Transmission: 700R4 / 4 Speed Automatic
Anyone have a V6 tach for an 86 I will trade you for a v8 tach.
Old Mar 4, 2017 | 06:25 PM
dwyczalek's Avatar
Car: 1984 Pontiac Firebird
Engine: 305 Chevy 5.0 Liter
Transmission: 5 speed Manual
Axle/Gears: unsure
Left front side of engine on cylinder head (on V-8 engine) temp sender for gage/light the one at the front of the engine is for the COMPUTER
Old Jun 30, 2017 | 12:49 AM
Albalushi1986's Avatar
Car: Camaro
Engine: 5.0
Hi there,
I have camaro 1991 rs (v8), i want to change the speedo to 1989 model, can you please advice ?
Old Jun 30, 2017 | 01:16 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Won't work. Your RS gauge is electronic, the other is cable driven. No fit physically either.
Old Jun 30, 2017 | 01:17 AM
Car: Camaro
Engine: 5.0
Anyway that i can customize it ?!
Old Jun 30, 2017 | 08:56 AM
John in RI's Avatar
Sure; Pull the entire dash housing and all it's wiring from your 91 and install a 82-89 Dash housing and wiring harness in it's place,...... than re-wire everything.
Old Jun 30, 2017 | 09:04 AM
Car: Camaro
Engine: 5.0
I wont do that. Ill sort it out with a better/easier way.
Old Jun 30, 2017 | 05:13 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
That is the easiest/best way. Any other choice would be Insanely
complicated
Old Jun 30, 2017 | 06:27 PM
NoEmissions84TA's Avatar
https://intellitronix.com/catalogsea...sult/?q=camaro
You can sometimes find these on ebay also. Cheaper too.
Old May 16, 2022 | 03:42 PM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Axle/Gears: Ford 9"moser 31 spline 350 gears
I know thread from the dead.... but i'm hoping someone can help.. my 85 iroc dash is broken.. i have a 91 dash ... what i'm planning on doing is swapping in an ls3 and t-56 from Hawks .. so the computer and everything OEM will be gone.. now will an 85 OEM housing with after market gauges bolt up?
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
