Door Panel Upholstering [pics]
Old Jan 15, 2009 | 04:31 PM
einarak's Avatar
Car: Camaro RS
Engine: 327
Axle/Gears: Alloy axles, motive 3.73
I just reupholstered my door panels with some leftover leather I had. I´m quite happy with the results and the leather is a perfect match to the 02 TA Ebony interior i´m installing in my 89 RS
This is how it looked after 20 years of service, one piece of shi...
The old one stripped
5mm foam insert
And the final piece
Old Jan 15, 2009 | 04:39 PM
popballz's Avatar
Car: 89 firebird
Re: Door Panel Upholstering [pics]
got any more pics of when it was finished? i really needa do this, but idk how i wanna go about it
Old Jan 15, 2009 | 05:04 PM
einarak's Avatar
Car: Camaro RS
Engine: 327
It actually looks better in real life, its just hard to to take a photo of it because of its dark color, and the reflections show all crimps...
Old Jan 15, 2009 | 09:56 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Black shows everything!
What type of foam did you use behind the material?
I have found if you use the thin stuff (less than 1/4")
and use the adhesive as well, it becomes uneven
it gives it a dimpled effect
Would like to see it in the car with the armrest, window crank and thee rest of the plastic on.
I do automotive trim for a living, any questions - just ask
Old Jan 16, 2009 | 03:06 AM
einarak's Avatar
Car: Camaro RS
Engine: 327
I´m a newbie to upholstering, so this was mostly driven by imagination... I don´t know what this foam is called, but its similar to the one thats original on the panel. I bought it from my local upholstery shop, this is what he uses on leather couches and that kind of stuff.
I sprayed adhesive all over the panel, foam and fabric... I was thinking only to glue the edges but thought it would come sloppy by time.. You think I should rather have done it that way?
Old Jan 16, 2009 | 06:23 AM
AC's Avatar
AC
Car: Used to drive a camaro
einarak, you did a decent job. I just did the same thing, going from the exact tan color (different style though) to a black panel. I used an edge trim from this place for my panels:
http://www.yourautotrim.com/snapontrim.html
Here's some pics of how it came out:
http://www.necamaro-firebird.org/for...hp?f=25&t=2249
Attached Thumbnails Door Panel Upholstering [pics]-picture-003s.jpg   Door Panel Upholstering [pics]-doorpanel_01.jpg
Old Jan 16, 2009 | 12:43 PM
VeracityZ28's Avatar
Car: 2 1991 Camaro Z28's both 5.7L TPI
Transmission: 700 R4
Axle/Gears: Stock 3.23 Limited slip
im redoing my interior too, im using white vinyl that my father still had in rolls from the early 80s. awhile back i did my t-top rs with leopard **** and i still have the speaker covers and door panels, plus the headliner. but i couldnt use that in my z28 because its a hardtop. so i think im just going to go with the white vinyl for the door panels. im still wrking on them though. ive done a lot of other stuff though.i plan on doing the center console bottom too where the carpeted part is. then the kick panels, and all the spots that used to have carpet on the back and rear plastics. check out the pics. any constructive advice anyone ?
Attached Thumbnails Door Panel Upholstering [pics]-mix-interior-mods.jpg   Door Panel Upholstering [pics]-interior-mod-mix2.jpg   Door Panel Upholstering [pics]-interior-mod-mix3.jpg
Old Jan 17, 2009 | 12:45 AM
popballz's Avatar
Car: 89 firebird
is that carpet on the bottom? mind telling me how much that stuff is?
and did you just fold it under it self and sewed it?
how does that look in person? ( like is there a bump or anything?)
thanks
Old Jan 17, 2009 | 04:34 AM
einarak's Avatar
Car: Camaro RS
Engine: 327
thanks
Thats a teflon coated automotive carpet, I bought one 55x 24 inch piece for around 25$.
yes thats exactly how i did it, and then cut the fabrics close enough to the sewing so there is almoust no bump. There is more visual bump where the leather pieces are sewet to gether on the upper part. Beside the door armrest covers about 50% of the middle line when the panel is in place so thats less to worry about.
Old Jan 19, 2009 | 05:38 PM
einarak's Avatar
Car: Camaro RS
Engine: 327
Well, finished the other one yesterday and test fitted one in to day, I´m really happy with the results...
Size:  71.1 KBName:  IMG_6608.jpg
Old Jan 19, 2009 | 07:59 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I've been following this thread and I have to say they look pretty good installed. I had my doubts whan I first saw the pic but good job Now for my next question, do you have the material to do the drivers panel with the same pattern
Old Jan 19, 2009 | 08:43 PM
Axle/Gears: unknown
Sorry to be gone so long
Looks good, installed
Straightening out the warped top plastic piece is kind of tricky, though
Broke 3 of them the first 3 attemps, but got it down pat now.
I am currently redoing my 91 GTA, I will post pics as I get them done
Great job upholstery newbie, you said it
Old Jan 20, 2009 | 05:02 AM
einarak's Avatar
Car: Camaro RS
Engine: 327
Thank you, I´ve already done the driverside panel. I´m having iltle trouble with the top plastic on that one, I broke off few of the pins that hold it to the panel becouse it has some kind of really stuck "one way" shims...
Old Jan 20, 2009 | 05:45 AM
AC's Avatar
AC
einarak, those "shims" are actually like thin nuts. You need to unscrew or back them off carefully from the plastic pins. If you're not carefull you'll strip the plastic post and the nut won't grip anymore.
For straightening out a top plastic trim piece I find a heat gun to be my friend.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
Out-Cast
Aug 23, 2015 06:33 AM
