84 z-28 camaro (help)
Old Jan 15, 2009 | 05:29 PM
AustinZ28's Avatar
I has been sulking around and finally register for this question.
I am in progress of taking my front seats out. I already take passenger seat out and going over to driver and I figured that I need to move my seat forward to get to 2 bolts behind the seat.
Heres the problem; The seat is electrical, I already cut the wires off...
How can I move seat forward without hook wires up again?
picture of my car
need to paint her
Old Jan 15, 2009 | 06:32 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: 84 z-28 camaro (help)
Umm, I don't think you can just make a quick splice to a power source even if its straight to the battery. Unless you completely cut the wires all the way, why you would do that is beyond me
Old Jan 15, 2009 | 07:05 PM
AustinZ28's Avatar
I am because I am going to get another seat. So the wire will be useless to me. Some guy here in Austin want the front seats. So I think i can cut the wires but above plug. Im stuck. Would I have to splice the wire and hooked them up to battery and move the seat forward?
Old Jan 15, 2009 | 08:21 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
You should try to hook the seat up to a battery, which would work, or as I was able to do on my '72 Lemans, (this may not be relevant in your situation) reach under the seat with a pair of vice grips and turn the boltt about 1/10 of a turn at a time.
Old Jan 15, 2009 | 08:33 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I dont see why you just didnt unplug the wires? I had an 84' Z28 with power seats, and it had a plug...
Old Jan 15, 2009 | 08:40 PM
AustinZ28's Avatar
I will try hook it up with battery and see how things re going,
for your help.
Yes I would unplug it too but a guy need the plugs on both side.
Should I get different wheel for my Camaro? Its American racing version 1 of something.
Old Jan 24, 2009 | 12:00 AM
X_Demonite_X's Avatar
Car: 06 impala 87 iroc z-28
Engine: 350 5.7 TPI
Axle/Gears: Pontiac WS6
i just had that problem with my camaro the seat motor was fryed and all the way back i had to take the whole seat rails off it was just 4 bolts triky to get at through 2 in front and 2 in the middle area ... hope u have skinny arms and good dexterity
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
