door panel removal question
Car: 84 Z-28, original owner
Engine: 305HO,+.030, mild cam
Transmission: TH700R4
Axle/Gears: 3.08, highway gearing, posi
84 Z-28 interior door panel - I have removed the armrest and removed the mounting screws for the black plastic cover (over the door handle, elec door lock switch and manual doorlock slide) - I can pull it out about a half inch from the upholstery panel - how do I remove/loosen/detach the manual doorlock slide so I can remove the plastic panel - I am tugging and pulling, but there is apparently a trick or method to unhook the doorlock rod so I can remove the panel without breaking it? HELP ! Thanks.
Axle/Gears: 9-bolt/3.45
Re: door panel removal question
With all the tugging and pulling you've already done, I'm surprised you haven't accidently figured it out already.
But you won't be removing the rod, itself. The black/red plastic "slider" is just a piece of trim on the end of the rod, and that's what you'll be removing. And it simply "snaps" onto the rod. The rod is "L" shaped on the end(like the plastic piece), and that's why the piece seems hard to remove. So just pry up the front edge of that piece, and then you'll be able to pop it off completely.
you guys are great help* -* I appreciate your time and your advice.... I am the original owner of this car (bought it off the showroom floor) and am doing a number of projects related to weatherstripping and window seals,did not want to start off by breaking something.* I think I have found most of the parts I will need in Classic and SoftSeal and Metro catalogs.* THX,* bob
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
