Steering hub question
Old Feb 4, 2009 | 02:31 AM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Question for you guys...My car appears to have a 1970's camaro steering wheel (which I HATE). Ive found another steering wheel to buy (going back to factory wheel) but it doesnt come with the steering wheel hub. So, my question is will the hub that is on my car now work with the factory 1988 steering wheel or do I need to buy another hub?
Here are some pics
If I need another hub where do I buy it?
Old Feb 4, 2009 | 03:36 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Steering hub question
the factory wheel (3rd gen) should have the hub attached to it.... not sure if the hub is attached to the current steering wheel. Do you have pics of the 3rd gen wheel?
Old Feb 4, 2009 | 06:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As a side note, when you swap steering wheels, swap that little clip as well (after throwing on a Grant a few years ago, I didn't and the nut had a tendency to loosen up, so much so that on vacation I was forced to stop at a shop and tighten it up).
JamesC
Old Feb 4, 2009 | 11:05 AM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Here is a pic of the steering wheel Im buying. Is that the hub or do I need something else? Also, will I need a steering wheel puller?
Old Feb 4, 2009 | 12:40 PM
HCR13's Avatar
Car: 1987 Trans Am
JamesC
X2 .....mine actually came off at a Sonic Drive thru!
something doesn't look right about that wheel, there should be a hole in the middle where the steering shaft should go through so you can tighten it down... maybe its becasue I'm not familiar with Camaro wheels, but all the ones I've seen have a hole, other than that, it looks like the hub is already on there...minus the hole...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
wild1
Aug 27, 2015 09:01 AM
redmaroz
Aug 16, 2015 11:40 PM
