C5 Corvette Sport Seat Swap
Old Feb 7, 2009 | 10:34 AM
jliroc's Avatar
Car: 1990 IROC Convertible
Engine: 5.7 TPI, L98 Heads w/roller rockers
Hey all,
I have a set of C5 Corvette sport seats I am wanting to install in my 90 IROC vert. I know there will have to be modification but I want to know if I drill holes is there anything under there that will be compromised. I work at a shop and have examined the area and it looks ok, but I want to make sure. Also want to know wiring hookups to allow the seats to work properly. Let me know please!
Old Feb 7, 2009 | 10:39 AM
jliroc's Avatar
Re: C5 Corvette Sport Seat Swap
fyi the seats in it now are manual not electric... if that helps
Old Feb 7, 2009 | 10:46 AM
Stephen's Avatar
Car: 87 GTA
Before drilling new holes in the floor...I'd set both seats side by side, upside down, and see if the F-body seats tracks could b e swapped over to the Vette seats.
Might hafta do some cutting & reworking of the seat tracks, but I'd be leary of new holes in a floor pan, since they might not end up in a strong spot & rip through under hard braking/cornering/impact. Granted, you could reinforce that area with BIG washers/plates etc. but..... :dunno:
Any pics of these seats?
Old Feb 7, 2009 | 11:19 AM
jliroc's Avatar
yes sir!
http://picasaweb.google.com/AutoWiseCC/DePewDan#
I just finished putting in black carpet, now I just need new seats!
Old Feb 7, 2009 | 11:34 AM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
those are not manual lol. i agree see if you can get the 3rd gen tracks to fit somehow. less new holes the better
Old Feb 7, 2009 | 11:36 AM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
if you drill holes to put in these seats I would get one of those bars you can find at a local hardware store that has holes all the way across and have a bar going from the left to right on the rear and one from the left to right on the front. Then go back and spray under coating. Just my opinion. Good luck the seats are sweet.
Simular to this
Old Feb 13, 2009 | 09:55 PM
jliroc's Avatar
got the drivers seat in!
http://picasaweb.google.com/AutoWise...93225581373922
Old Feb 13, 2009 | 10:33 PM
Paragus77's Avatar
Car: 1986 Sport Coupe
Engine: 305 Carbed
Transmission: th700r-4
That looks bad ***, dude!
I remember thinking that those sport seats where the coolest damn seats I'd ever seen, and wondered if anyone would ever put them in a thirdgen, you have given me hope!
Old Feb 14, 2009 | 12:44 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
they fit with 4th gen tracks im runnin em.
Old Nov 15, 2009 | 02:14 AM
newfie_rs's Avatar
Originally Posted by jliroc
hey im doing the same seat swap i was wondering if you got the power hooked up and if so can you tell me what i meed to do i got how to install the seats in the car but the wireing i cant figure out.
Old Nov 15, 2009 | 11:32 AM
jliroc's Avatar
there are two main wires off of the seat harness, power and ground. those control all seat functions, including the adjusting bolsters. My car did not have power seats, so I had to make a new harness, I used an inline fuse (25amp) and a quick disconnect in case I had to pull them out for some reason. I also made a power distribution block for any additions I put on. It works great! Post pictures man!! Good luck!
Old Nov 15, 2009 | 12:20 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
anyone got weight figures on these seats? looking good to me
Old Nov 15, 2009 | 01:07 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
So what you end up doing?? You drill some holes or swap tracks??
Old Nov 16, 2009 | 09:38 AM
jliroc's Avatar
drilled holes, had to put a new bracket in underneath, but it worked perfect and looks awesome
Old Nov 16, 2009 | 03:14 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
Nice job man, those seats are sweet. I love to see people doing their own thing
Old Nov 16, 2009 | 03:25 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
i did the same thing a while back while doing my 4th gen dash. they look really nice. i have the drivers side electric as well
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Hello, Michael
Aug 20, 2015 03:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
