ashtray light
Old Feb 9, 2009 | 07:52 PM
rodsatheart's Avatar
Car: 1992 camaro RS
ashtray light
Does anyone have a ashtray light assy. they are willing to sell. I'm needing everything including the pigtail.
Brien
Old Feb 9, 2009 | 09:25 PM
thegooseman's Avatar
Car: 1992 RS
Re: ashtray light
Our ashtray's have a light?
Old Feb 9, 2009 | 09:44 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: ashtray light
Do you mean the console light that's under the dash panel?
Old Feb 10, 2009 | 04:39 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: ashtray light
Yea, have that in mine. On another thread called "light above HVAC" there is a lot of info on it. Also a neat LED conversion.
Old Feb 10, 2009 | 04:58 PM
Car: 1992 camaro RS
Re: ashtray light
Yep, That's the one. On the 92 it's a snap it bezel and the socket will accept a 161 bulb which is a little over a watt brighter than the 74.
Old Feb 10, 2009 | 08:54 PM
vette gator's Avatar
Car: 85 Z28
Re: ashtray light
Thanks so much for that picture! I've read about this light in other threads but never could find it in my car. Now that I see it, I understand why I have two cracked holes where a previous owner must have removed mine with a jackhammer or a bazooka.
On a related note, anyone have one of these they would like to sell?
Old Feb 10, 2009 | 09:07 PM
Axle/Gears: 3.08
Re: ashtray light
You're welcome. Sometimes a picture's worth a thousand words for some of these more obscure items. The best place to find one is probably somebody parting out their car or an autowrecker. Good luck.
Old Feb 10, 2009 | 09:10 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: ashtray light
wow i have had my 91 for a long time and never saw that ill have to see if i have one. weird. recently i broke a rear view mirror so i bought more interior lights bc it was dark. ill see if that one would help to make it brighter for the misses too.
Old Feb 16, 2009 | 02:10 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Re: ashtray light
You can get a bit more light by making the pinhole where the light comes out larger. You have to carefully remove the small clear lense on the light unit and carefully drill it to what you need. Be very careful when doing this or you can crack the unit.
Old Feb 16, 2009 | 07:08 PM
chris.niemann84's Avatar
Car: 1985 IROC Z28
Engine: L98 - 350/650 Holley DP
Axle/Gears: 3:83 Full Spooled
Re: ashtray light
ok, now the picture shows a light under the dash, however all i have is two holes where the screws were at, but no hole where the wires were run to it at... how does this work out? does anyone have one that they could get rid of to put back if i were to find out how this thing hooks up...
Old Feb 16, 2009 | 09:44 PM
3rdGenIrocZ's Avatar
Re: ashtray light
ohh now i know what that light is now lol. hmmmm that explains alot
Old Feb 16, 2009 | 10:14 PM
Q's 91z28's Avatar
Car: 91 Z28
Transmission: Automatic
Re: ashtray light
WOW!! Just realized I had that light, and it actually works
Old Feb 16, 2009 | 10:35 PM
Car: 1985 IROC Z28
Re: ashtray light
ok, everyone can quit rubbing it in and just tell me where i can get one at... LOL if anyone is willing to unscrew theirs and take a picture of the mounting surface with it off, that would be great, like i said. i only have 2 holes where the screws went and no 3rd hole for the wiring, also, what color is the wires that go to that to see if i even have them in my dash anywhere...
Old Feb 17, 2009 | 01:04 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: ashtray light
I have that in my car but no switch to turn it on.Can someone post a pic of where their switch is so I can atleast put one in the stock location?thanks
Old Feb 17, 2009 | 12:20 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Re: ashtray light
It goes on when you turn on your parking lights or headlights. The bulb may be burnt out. The bulb number is 74.
Old Feb 18, 2009 | 12:31 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: ashtray light
Cool,I`ve been wondering what that thing is.
Old Feb 18, 2009 | 10:41 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Re: ashtray light
No problem. Yea, I tripped out when I first learned I had this funky little light.
Old Feb 18, 2009 | 07:58 PM
Car: 1985 IROC Z28
Re: ashtray light
ok, well since everyone is going to just ignore me and not help me out by telling me if anyone has an extra of where i can get one (Oriley's, AutoZone, Advance, etc. ) non of them have on in their books... so anyways, thanks to NOBODY for helping out on that one, preciate all the help that NOBODY gave me..
LOL
Old Feb 18, 2009 | 08:02 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: ashtray light
Try radio shack.You cant find the replacement third brake light bulbs for my car anywhere but there.
Old Feb 18, 2009 | 08:08 PM
Car: 1985 IROC Z28
Re: ashtray light
LOL... thank you, but i meant the actual light enclosure (the plastic) part....
Old Feb 18, 2009 | 09:17 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: ashtray light
I just went to advanced and picked up the 74 light but I saw a 161 and there is no way the 161 would fit.Itwas huge.The bulb was the problem.The light works fine now.
Your prolly going to have to search the junkyards for the enclosure and all.Nobody is going to be making that still.
Old Feb 19, 2009 | 06:04 PM
Ls2 GTO's Avatar
Car: 92 purple haze z03 z28
Engine: Lb9
Transmission: 5 speed
Re: ashtray light
Has anyone changed the bulb in a trans am. I pulled the dash apart and found the part but it not just a replacement bulb , it is more of a whole assembly with 2 wires connected to it .
Old Feb 19, 2009 | 07:00 PM
Car: 1992 camaro RS
Re: ashtray light
The later one as for my 92 is supposed to take the 161 bulb. I'm assuming that they figured out that the 74 was just a little to dim to do the job. The 161 is about 1 watt brighter, but takes a completely different mounting set-up. If I can get the camera working I will get a picture. I'm probably going to have to try and find a 2 or 2.5 watt incandescent bulb and socket from Radio Shack and modify the mount.
Old Feb 19, 2009 | 08:02 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: ashtray light
Im the one who did the LED conversion, if yall want i can do a real detail actual post on it PM me or something and tell me if yall want me to do it, i also made a LED light for your center console so you can see your crap it it
here is the link on the light
https://www.thirdgen.org/forums/elec...-controls.html
im bumpin it also to make it easier to find
Old Feb 19, 2009 | 09:24 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: ashtray light
rodsatheart, is this what you're referring to? Here are pics of the top and bottom of the light. Here's what the mount has written on the back, but you can't see it due to the poor quality of the pic:
1st line: 10181789
2nd line: OLP 2 PPO
This came from my '91 RS
chris.niemann84; my '85 has the two screws in the holes, but doesn't have, and obviously never did have, a light there. I never looked, but I assume the screws also serve another purpose, so just because the holes are there for those screws on your car, doesn't mean it once had, or was meant to have a light there.
The wires are black and gray.
Edit: The light on my '91 wasn't held in by any screws, it just pops in to place.
Also, is there a separate RPO for this light?
Old Feb 21, 2009 | 07:35 AM
Car: 1992 camaro RS
Re: ashtray light
That is it. Know anyone that has a spare setup or at least the pigtail assy. ?
Old Feb 21, 2009 | 11:20 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: ashtray light
The one in the pics isn't being used.
Interested? Free + shipping...
Old Feb 21, 2009 | 01:22 PM
Car: 1992 camaro RS
Re: ashtray light
Pm me and we'll work out the details when I get home tonight at 8:30.
Old Feb 22, 2009 | 08:38 PM
Car: 1985 IROC Z28
Re: ashtray light
yeah, i guess that mine wasn't meant to have the light. however, i did find one in a junkyard though. it is the screw in type. i grabbed it in case anyone on here wanted it, however because it has sat so long, the little tabs that hold the plastic casing around the light have broke off so it don't "lock" into place anymore, however, a little super glue will work just fine on it. I will have pictures later on to post in the classifieds and will attach the link to here to if anyone is interested. it'll be free + shipping or COD. if anyone is interested before I post let me know PM. also, couldn't get all the way back to the harness clip so the wires are just cut (plenty of wire to spare though). if no PM's by the time I get back on here i will just post it in the classifieds.
Old Feb 22, 2009 | 10:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: ashtray light
Ls2, ours is a neon light inside a tube... I replaced that a long time ago with an LED assembly from RadioShack by cutting the connector off of the original and splicing in the new wires. Unfortunately, the bulb assembly I have doesn't shine into the ashtray area (not that I need it to do that anyways... only thing I have down there is my iPod interface connector). What would need to be done to fix this is to make a hole in the lens at the bottom of the cluster trim to mount the lamp to. And of course to not get a blue one... they're pretty dim.
Old Feb 23, 2009 | 04:39 PM
Ls2 GTO's Avatar
Engine: Lb9
Re: ashtray light
Thanks Maverick I'll try that.
Old Feb 23, 2009 | 05:08 PM
ryan91rs's Avatar
Transmission: 4L60
Re: ashtray light
haha i looked and i have one. weird. Never noticed it and not going through the process of putting in a LED. that's not worth my time honestly. might pop it out and clean the lens though.
Old Mar 1, 2009 | 06:54 AM
Car: 1992 camaro RS
Re: ashtray light
Got the light. Just what I was looking for.
Old Mar 8, 2009 | 11:18 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
Re: ashtray light
This is just bizarre - I have never noticed a light on my '88. It's too late to go check but if it's there in the morning I'll flip. I've always thought more light was needed.
BTW - Great weather today for a cruise. 26 miles along the Gulf on Santa Rosa Island - topless of course.
Old Mar 10, 2009 | 09:56 PM
gatorcola's Avatar
Engine: LB9 5.0 tpi
Re: ashtray light
OK, what's the deal. I have it but what's it for? In over 20 years I never noticed any light; and yes it still works. It is more of an obscured indicator light than a functional light.
Old Mar 10, 2009 | 11:04 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Re: ashtray light
Here is the 1991 light assembly exploded. I cut the wire to the old bulb to remove it and soldered a new one on then epoxied the wire to the outside of the housing. a 12V LED would fit very nicely in there but I re-did with the same as before.
Old Sep 2, 2013 | 11:37 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Re: ashtray light
Sorry to bring up an old thread, but no where on this forum have I found a lot of info on this part. Its not in any assembly manuals and it seems to only be on certain cars. I for one wanna know more about it.
Edit: FOUND something
Number 52
http://parts.nalleygmc.com/showAssem...ssembly=380687
Old Sep 4, 2013 | 01:59 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: ashtray light
Some early third gen camaros had a fiber optic cable from the shifter indicator to the ashtray, not very effective either.My 84 has it.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
