Did they make two different door handles?
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
As the title says did they change the interior door handle (other than color of course) ?
I was on a site and they had a black interior door handle for a 82 to 87 car.
Are the 88 to 92 ones different?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: Did they make two different door handles?
as far as i know camaro never changed but.... the potiac trans am gta delux door style from 88-92 had these smaller triangle style bezel trim fro the door handles but i think the actual handle itself was the same
"i think"
"i think"
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Camaros - All same Handles
Firebirds - When they started using the different style of plastic bezel that surrounds the handle, they incorporated a new mount , for the new style bezel to screw into, the assembly is the same, just a small piece of metal, with a tapped hole in it.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
