made myself some new door panels!
Old Feb 15, 2009 | 09:03 PM
popballz's Avatar
Car: 89 firebird
well when i got a new door, i decided it was time to make some new door panels!
so it went from this:
to this:
Old Feb 15, 2009 | 09:04 PM
popballz's Avatar
Car: 89 firebird
Re: made myself some new door panels!
Old Feb 15, 2009 | 09:05 PM
popballz's Avatar
Car: 89 firebird
Old Feb 15, 2009 | 09:06 PM
popballz's Avatar
Car: 89 firebird
so many post cuz of the pic limit per post
its basically the same, but the new ones is new board and materials, and it looks new, the old were all sloppy and dirty and worn out
Old Feb 15, 2009 | 09:26 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
What did you use for backer board and where did you get it? Also what type of difficulty rating would you give this? Is it something you do regularly or is this your first time. If its a first time job its a damn good one, what is that vinyl and suede? I've been thinking of something like this for my own vehicle.
Old Feb 15, 2009 | 09:34 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Wow! Great job. Looks good. If mine were in bad condition I would try this, but mine are pretty nice so no need.
Old Feb 16, 2009 | 12:05 AM
popballz's Avatar
Car: 89 firebird
its some wood stuff, i think its called masonite, i wanted something stronger then that cardboard stuff that was originally in there
its my first time, and it was not that hard, it just took some time and patience
Old Feb 16, 2009 | 12:13 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
this looks nice. great job
Old Feb 16, 2009 | 09:16 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Very nice job. You could make some mooney doing that for people.
Old Feb 17, 2009 | 03:19 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Real nice, but where did you find that vinyl material? Ive been looking for some, and can't find any in black.
Old Feb 17, 2009 | 07:03 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
http://www.yourautotrim.com/boauvi.html
Old Feb 17, 2009 | 07:07 PM
popballz's Avatar
Car: 89 firebird
haha, anyone wanna buy some?
you got a JoAnns fabric store around you? thats were i got mine, and i got it 50% off too!
Old Feb 17, 2009 | 10:11 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
turned out pretty good there. like it better than stock. upper carpet looks like velour or soemthing like a plush, nice
kinda showed what i went from and too. first pic is the original door. this was the driver door but the passenger side door was all black bc i had to cover it bc it was messed up from water etc so picture it worse lol. i wanted aluminum panels. so this is what i did.
cost me 85$ for 2 panels that i just cut to fit. also installed two 6.5" speakers to make my new system 8speakers
pic one before (nicer driver door)
pic 2 finished aluminum panel.
Attached Thumbnails made myself some new door panels!-p1010289altered.jpg   made myself some new door panels!-p1010349altered.jpg
Old Feb 20, 2009 | 12:03 AM
tekkitan's Avatar
Car: 87 IROC-Z
how much?
Old Feb 20, 2009 | 02:49 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Masonite is also commonly known as Hardboard, and can be found at Home Depot or Lowes. They look nice :-)
Old Feb 20, 2009 | 03:09 PM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
[quote=popballz;4047558]haha, anyone wanna buy some?
Yeah seriously how much?
Old Feb 22, 2009 | 10:59 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Be careful about which "masonite" you buy from home depot or lowes!!
There is some masonite made from eucalyptis wood (spelling not correct)
That is good for automotive use
The softer "masonite" will warp if any moisture is present
High humidity counts in this as well
Make sure you install a vapor barrier behind the door panel
You know that bothersome plastic sheet that is in your way when you go to change a power window motor.
This keeps the water that seeps past the window from affecting your door panel
I haven't tried it myswlf, but a water repellant, aka thompson's water seal or something equivelant should be applied to the masonite, if you purchase the softer type from your local store
Part of my job is to fabricate interior panels for brand new fire tucks and other automotive upholstery issues as well. We (my employer) steers away from the softer masonite from home depot or lowes, because experience has shown that what I explained above will occur.
Nice job on your door panels
I would post some pics of my interior, but digital camera and computer stuff is not a strong area for me, maybe in the future
Old Feb 23, 2009 | 11:16 AM
bboyghost's Avatar
Car: 91 Rally Sport
Engine: 305 TBI
I would also be very interested! How much!?!?!
Old Feb 24, 2009 | 05:59 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Doggone those look wonderful! I've had that idea bouncin around in my head, and now seeing you do the project makes me want to get mine done. Thanks for the inspiration! Good craftsmanship!
Old Feb 24, 2009 | 07:45 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
That looks nice! My wife and I are getting ready to do ours. We are going to be using courregated plastic (Basically it is cardboard box material that is made from plastic.) It also has the advantage of being lighter than masonite and impervious to water. (A must for the typically leaky thirdgens) It's nice to see someone tackle a project like that, as most people dont have the nerve to even try it.
Most major citys have a bunch of "Auto upholstery supply houses". It's where most of the auto upholstery shops go to met their most common materials such as vinyl and velour. Check your local phone book for auto upholstery supply.
Old Feb 24, 2009 | 07:55 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Those are pretty cool.
Old Feb 25, 2009 | 11:23 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
why two different colors on the door arm rests?
nice job.
Old Feb 26, 2009 | 09:08 AM
BowtieZ28's Avatar
Looks nice, good job.
Old Feb 28, 2009 | 07:27 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
nice job.
it looks like the gray was before and the black is after. I think the black is a nice improvement.
Old Mar 17, 2009 | 07:55 AM
Car: 1971 Camaro
I just made some new door panels for myself using the same method you used.
I think I have about $50 in both sides.....a whole lot cheaper than paying the supply houses $150 + shipping for repros.
Old Mar 17, 2009 | 11:29 AM
popballz's Avatar
Car: 89 firebird
nice job.
damn, i guess i missed that post! i had gay, but they were all dirty, really dirty, with red paint on them, so when i got a new door at the junkyard, i grabbed the other side(black) and i think it looks alot better with black!
those look great! was it hard getting that top black piece on? mine was since it was so think.
Old Mar 17, 2009 | 11:43 AM
Car: 1971 Camaro
Yeah it was tough getting the top piece on, I ended up cutting some material away around the upper openings in the hardboard.
I also sanded that area down to about 1/16" thickness enough for the nuts to bite onto the studs for the upper rails.
It was basically too thick and the nuts couldn't grab
Old Mar 20, 2009 | 06:58 AM
alienbishop's Avatar
Car: 1991 Camaro RS
Engine: In the process of swaping to 3.4
Transmission: Automatic
Great job man! I think i am going to try to do it also
Old Mar 20, 2009 | 01:15 PM
mongo136's Avatar
Car: 89 camaro rs
Engine: 468 bbc
Transmission: powerglide
Axle/Gears: 373 S-60
Looks nice, I have to do something similar, but i have to delete the arm rests,(cage issues) any suggestions so it doesnt look so plain? I want to do it my self so sewing in a bowtie isnt happening!
Old Mar 20, 2009 | 02:25 PM
bigstack10's Avatar
Car: 92 Camaro RS
Engine: v6 3.1
Wow, looks real good
Where would be The first place to start?
Do i just pop the whole door panel off?
Old Mar 20, 2009 | 02:44 PM
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
It is looking good.
My panel is out since two month, I am building mine slowly... I took the exact same cardboard as the original (around 6 or 8$). One fabric that looks exactly the same and one other is a bit different (I did not liek the carpet style). I think I will stay under 80$ for both door, may be a bit more with all the small expenses.
What "strip" did you put? I have some cheap one (about 1$ a yard), it looks but does not bend very well, and I dont know if it will glue enough.
Old Mar 20, 2009 | 07:25 PM
popballz's Avatar
Car: 89 firebird
Do i just pop the whole door panel off?[/quote]
yep, pop it off and go at it, you also might wanna start with buying the materials!
Originally Posted by loopingz
It is looking good.
the black thing that separates the two fabrics?
thats stock on some firebirds, like mine, and probably the other guy's
Old Mar 24, 2009 | 06:54 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Yeah they look great!!!!!!!!!! I basically have had the Ideato do the same thing to mine only I am going to use black and red vinyl to match my paint job.
Old Mar 24, 2009 | 08:41 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
i was thinking of doing the same thing, where did u get the panels from and does the sun get them hot enough to where its not friendly to the touch kind of like seat belts
Old Mar 25, 2009 | 03:25 AM
Louis_84's Avatar
Car: 1984 Camaro SC
Engine: 305 V8, LG4. For now...
Transmission: 700R4, for now...
Axle/Gears: ???
sweet
Old Mar 25, 2009 | 04:01 AM
Nub383's Avatar
Car: 94 Silverado
Engine: 383 Vortec TBI
Transmission: 4L60
You could take the peices of material to a shop and have the embroidered. It costs 10 for like a 6" bowtie around here. Or find a rest home and pay some granny to do it.
Old Mar 28, 2009 | 08:39 PM
Car: 1971 Camaro
Got my door panels on today, I added some fatmat and new weatherstipping while they were off...the doors are nice and solid feeling now.
went from this:
To this:
Old Mar 29, 2009 | 12:00 PM
aciddrop2804's Avatar
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
That kind of reminds me of a nintendo controller...same color scheme
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
Out-Cast
Aug 23, 2015 06:33 AM
