Need 92 Camaro RS instrument cluster
Old Feb 21, 2009 | 11:01 AM
Tamak's Avatar
I have been searching for an instrument cluster for my daughter's 92 camaro Rs but can't seem to find the right one. Most of what I have found is for a 6 cyl and hers is 8 cyl 305. Any suggestions as where I can look, or does someone have one for sale?
Old Feb 21, 2009 | 01:48 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: Need 92 Camaro RS instrument cluster
post in the parts wanted section that you need a 92 cluster
and use the search section above to see if anything pops up for what your looking for
and check out ebay.com
Old Feb 21, 2009 | 02:12 PM
deoverton's Avatar
Car: 1992 Camaro RS
Go to your local craigslist and put that your needing one. Craigslist has helped me many times.
Old Feb 21, 2009 | 02:59 PM
Tamak's Avatar
Thanks! I took your advice and posted.
Old Feb 22, 2009 | 12:11 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
I bought mine from hawks and it came with the older yellow needles. I only needed the speedometer so i swapped the odometer, the face and the needle. Works like a charm
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
