Are the "sideledges" naturally banana bent?
Old Mar 6, 2009 | 01:37 PM
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
I mean the plastic part on top of door panel, I have got three different and they look all bent. Is it the normal shape, or just the normal wear?
As I am fabricating new door panels I have to know so I can drill the holes in the proper positions!
Old Mar 6, 2009 | 08:42 PM
69-er's Avatar
Re: Are the "sideledges" naturally banana bent?
I'm sure it's an issue on all 3rd gens, especially in hot climates. My 83 started doing it when it was still under warranty. They wouldn't replace them because it was "normal." I was lucky enough to recently find a pair of NOS pieces along with the outer window felt/rubber.
I see them on eBay occasionally. You'll have to ask the seller if they are straight and take their word for it.
Old Mar 6, 2009 | 09:25 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
You can still get them new I think Hawks sells them I know Classic Industries dose.IIRC they are around $165 a set w/o felt.
Old Mar 6, 2009 | 11:34 PM
69-er's Avatar
Yeah, but they're reproductions. I was able to get my NOS ones for $150. Lucked out. Now, I'm afraid to install them cause they might warp too!
Old Mar 7, 2009 | 01:30 AM
loopingz's Avatar
Anyone tryed to reverse the process with some heat from heatgun directed from inside?
The things as I am redoin the panels, I can accept the bent shape or no. If it will be likely to break...
Old Mar 7, 2009 | 10:33 AM
69-er's Avatar
I thought about doing that. I think the only way would be to support it entirely from end to end, almost like the original mold and then apply heat. Doing it any other way would produce a wavy shape at best.
Old Mar 8, 2009 | 07:27 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I solved the issue with a screw to the rear of the plastic into the sheet metal of the door. It's so far back it's basically invisible because it's essentially in the back seat. It's countersunk so you don't catch things on it.
I made a thread about refurbishing these things.
https://www.thirdgen.org/forums/inte...-door-top.html
Old Mar 8, 2009 | 09:41 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I bought a set from a member on here, JimIroc (sp?). Haven't tried them yet, they're still in the box. My old ones aren't warped, but they are cracked.
gta892000
Aug 11, 2019 11:16 AM
Zell1luk
Sep 29, 2015 10:36 AM
mfp189
Sep 27, 2015 09:25 AM
RedLeader289
Sep 23, 2015 06:50 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
