Best way to go about Washing Interior Carpet
Old Mar 7, 2009 | 01:26 PM
Dogfrost9's Avatar
Car: 1984 Camaro
Transmission: 350 Turbo
I have Already removed the Carpet from my car, it is pretty dang dirty. Not just dirt but also some mouse crap, few grease marks. Overall just not pretty.
I really cant put it in our washing machine so i was wondering if anyone knows of a good way to wash otherwise, and maybe a good cleaning compound they used.
Old Mar 7, 2009 | 02:43 PM
deoverton's Avatar
Car: 1992 Camaro RS
Re: Best way to go about Washing Interior Carpet
Shoot it its already out I would pressure wash it.
Old Mar 7, 2009 | 02:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I had a professional carpet cleaner do mine. Turned out great.
JamesC
Old Mar 7, 2009 | 07:47 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
I just pressure washed my carpet today, scrubbed it with purple power cleaner and let it soak in for a while scrubbed it once more and spayed it clean. turned out really good, got a lot of scum out of it
Old Mar 8, 2009 | 02:58 PM
Dogfrost9's Avatar
Car: 1984 Camaro
Thanks for the input, Yea I think I'm going to Buy a pressure washer on Monday. Its a 2600 psi, I don't know much about pressure washers but that should probably do the trick.
Old Mar 8, 2009 | 08:46 PM
Duratys's Avatar
Car: 91GTA 89TTA
Engine: 305 3.8 Turbo
Transmission: MK6 2004r
Axle/Gears: G80 3.42s 3.27s
GPM (gallons per minute) is more important than psi.
What kind did you buy?
Old Mar 8, 2009 | 09:14 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I would start by hosing it down, then scrub the whole thing real good with a course scrub brush and bucket of hot water with laundry soap. Then rinse it off again with a sprayer nozzle or pressure wash.
Old Mar 8, 2009 | 09:15 PM
pentiuman's Avatar
I know you're talking about carpeting, but when I clean carpeted-based floormats at the carwash, it almost tore them apart. So, I own a powerful pressure washer, but would be afraid to use it on old carpeting (without turning down the amount of pressure, or using a lower pressure nozzle).
So, with my carpeting (in the car), I used the hand held attachment to a (house) carpet steam cleaner (and it's expensive cleaning solution, and some very hot water poured directly on the carpeting). Worked excellent!!! Had to also do this about 3 days when my window wouldn't go up all the way, and it rained sideways. (Before I promptly replaced the power window motors). Yes, you can use a pressure washer for a lot of other things, (washing your house before painting, cleaning driveways), but a steam cleaner is nice to have for house carpeting (especially if you have kids or pets). And, it may be easier convincing the wife to buy a new (house) steam cleaner, than it would be to buy a pressure washer - as she may consider that a tool.
- Personally, if I had my original carpeting already out of the car, it was real dirty, and I had the money, I'd go ahead and buy new (car) carpeting - if I could match the color and fit well.
- Also, if you do clean it and have any spots that wouldn't come out, consider new floormats. The rubber ones worked well and only cost $20-40 for a set.
Old Mar 8, 2009 | 09:46 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Put it on the back of a pickup and take it to the car wash. I did that with an Iroc that I had and it came out great.
Old Mar 9, 2009 | 10:18 AM
Dogfrost9's Avatar
Car: 1984 Camaro
I was actually going to look at it later today, But its a Honda with a 5hp motor. and 2600 psi. The add does not say how much gallons per minuet it has. What is a good GPM range?
Old Mar 9, 2009 | 11:09 AM
Duratys's Avatar
Car: 91GTA 89TTA
3-4 gpm is ideal.
RyanJB
May 7, 2016 06:23 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
ctoledo0834
Sep 18, 2015 04:16 PM
neilb
Sep 15, 2015 05:06 PM
MORREALE5
Sep 13, 2015 09:01 PM
