wanted t-top headliner
Old Mar 22, 2009 | 01:46 PM
irocman79's Avatar
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
i despertly need a ttop headliner. doesn't have to to be perfect can need to be recovered. Just don't want any abs plastic aftermarket ones. Hear they do not look very good. my backing board broke all to pieces when it took it out to restore my car top to bottom.
Old Mar 23, 2009 | 09:17 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: wanted t-top headliner
I have the same problem. You could look in the junk yards but I am not sure if they would be any better. Before I buy a new one I am going to try filling the cracks with fiberglass resin Jelly, then applying a smooth coat on each side of the cracked(or broken) area, and then laying over those fiberglass sheets. Then turn it over and do the same on the other side. Mine is mostly bad at each end because someone before me tried getting it off without removing everything. I figure its worth a try since there is nothing to lose. I was going to try and take a few pics and if its actually works , post it on here. Has anyone else tried this?
Old Mar 23, 2009 | 09:26 AM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
go here
http://www.classicindustries.tv/
Old Mar 23, 2009 | 11:33 AM
1Aauto's Avatar
Former Sponsor
Iroc, on the ABS ones,we sell a ton of those.It resolves the issue with the the pressed board oem ones that deteriorate over time,because of the abs backing.I know that the manufacturer had gone through great lengths to pre punch and holes to cut down on install time.
It would be more resistant to moisture too,because it's not pressed board backed.
If you have heard of a concern with fitment or apperance PM me and I'll check into it for you.
T
Old Mar 23, 2009 | 11:41 AM
irocman79's Avatar
did you but a ttop headliner from there any problems with fitment
Old Apr 16, 2009 | 10:31 PM
xChevy350x's Avatar
Car: 91' Camaro RS
I'd try the Boneyard. My Camaro came without one and picked one up from there for like 5 bucks. Bought Black Fabric for another 5 and a can of Duro All Purpose Spray Adhesive.$15 bucks an now looks brand new. You could also use a hot glue gun on the top to wrap the fabric on tight as well.
Hope this helps.
Old Apr 18, 2009 | 07:27 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Heard the same thing so I refuse to go that way. I pulled mine headliner completely out and soon as I can get my t-tops to stop leaking I'm doing the same thing to my board. I've heard good things and will take pictures as I go. No idea when it will be done though.
Btw I have the dark red (dark carmine) cloth seats and its hard to find that color. Found it at salvos in the end
Frozer!!!
Jan 19, 2024 04:55 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
gta90
Sep 15, 2015 04:00 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
