Heater temperature control cable bracket broken
Old Apr 8, 2009 | 05:09 PM
87350IROC's Avatar
Car: 87' IROC
Hi,
I'm going to be doing a heater core change this weekend and decided now is the right time to fix my temperature control cable bracket. The little metal bracket that connects the cable to the temperature door in the heater box is broken. Does anyone know how to fix this? Do I need a new temperature control door? Or a whole new heater box?
Thanks,
John
Old Apr 8, 2009 | 07:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Heater temperature control cable bracket broken
That's a good question I'd like an answer to as well. Mine has been broken for, let's see, now, four years or so now? I've tried to pull what was left of the lever off of the door shaft, pulling the box apart (with the exception of splitting it from the firewall), and nothing has helped. Actually, trying to pull the remnant of the lever off of the shaft only broke it worse...
Old Apr 9, 2009 | 11:34 PM
87350IROC's Avatar
Car: 87' IROC
I went to the dealer today. That part is discontinued. It was part number 3050740. Does anybody know how to replace one?
Old Apr 10, 2009 | 05:59 PM
rs camaro92's Avatar
Car: 1992 25th anniv. camaro rs
Engine: 3.1L V6
Axle/Gears: stock
Im not sure on how to repair the conntrol but i will say be careful the heater lines on the old one will probably fall off. Your gonna have a mess in the floor board so cover it up in some plastic, i just replaced mine 2 weeks ago.
Old Apr 10, 2009 | 07:57 PM
87350IROC's Avatar
Car: 87' IROC
Yeah I'm about to start a heater core replacement. So I figure I might as well fix that bracket while the core is out of the way.
Old Apr 16, 2009 | 04:43 PM
87350IROC's Avatar
Car: 87' IROC
anyone know how or whats needed to fix this?
Old Apr 16, 2009 | 08:17 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Mine is broke too, it seems to be a common problem. From what I understand it requires pulling the whole dash out which is beyond my skill.
Old Apr 17, 2009 | 09:09 AM
1Aauto's Avatar
Former Sponsor
I'd replace it while I was in there,heater cores are a pain in any car.I don't know why they don't make it easy for you, with like a trap door and a few bolts you could take out.
Old Apr 17, 2009 | 10:15 AM
87350IROC's Avatar
Car: 87' IROC
Thanks Tony. My plan is to replace both the heater core and the temperature control bracket. My problem is I don't know how to replace the bracket.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Genopsyde
Nov 11, 2015 10:46 PM
