Are individual gauge replaceable??
Old Apr 12, 2009 | 01:28 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Is it possible to replace individual gauges in our clusters or do u have to replace the whole cluster? I have a perfectly good 140 mph cluster in my car but the temp gauge is busted.. I'd like to just to be able to replace the temp gauge.. can I?
Old Apr 13, 2009 | 12:51 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
Re: Are individual gauge replaceable??
yes you can, just pull the cluster apart and they are each held in by one or two screws, its actually really easy, i have a temp gauge out of an 86 z28 i could let you have for a couple of bucks, shoot me a pm if you need it
Old Apr 13, 2009 | 01:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by CodyC123
yes you can, just pull the cluster apart and they are each held in by one or two screws...
That is, pull the bezels (plastic and metal) from the front of cluster while it's still in place. Plug and play. Twenty minutes top for the swap.
JamesC
Old Apr 13, 2009 | 01:32 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Hmmm, now that this is a recent thread, I've kinda been wondering something. Is it possible to swap aftermarket type gauges into the cluster with some slight modification? I was mainly thinking of a Tach to replace the stock tach (I hate the idea of having two tachs, one of which sticking way out somewhere). I'm mainly curious if the depths of the gauges are similar (the diameter can obviously be chosen.)
Old Apr 13, 2009 | 01:36 PM
89RsPower!'s Avatar
Thanks for the info guys, I had my cluster out many times on my old rs but never noticed if it came apart. I like the idea of just replacing the broken gauge rather then looking for a whole new cluster.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
ChevyZ71
Aug 13, 2015 07:30 AM
